| 6.7 Exterior Discussion 6.7 Exterior Discussion |
So my dad has a 2011 6.7 and wants to put a small lift on it. He mostly uses the truck for just driving around and towing a bumper pull trailer. Every now and then he pulls a gooseneck horse trailer so he doesn't want it to tall for that reason.
I have been looking around and want to get him something more than a leveling kit and have looked at a 3 inch kit. Can anybody suggest one? I am looking for something reasonably priced and a good product. Also with this type of lift what size tire and rim would you suggest? Also I dont know much about backspacing and offset so any information would be great! Thanks |
I can't remember what lift I was looking at, but it was 3.5" front and 1" rear (f350 lift), thought that was a pretty good combo.
If you have the 20" stock wheels, you have all sorts of tire choices near 35's. But with 18" stock wheels, I would not put 35" tires, because the rim is only 8" wide. (it's not the best idea to put a 12" wide + tire on a 8" wide wheel, if you tow) The tire look you want is all personal preferance. Personally I wouldn't go with anything smaller then a +10 offset. +40 is stock. |
Thanks! |
im looking to do the same exact thing
WE carry Pure Performance and Icon level-lift kits...if I can help please PM me.
Cary |
So if you found rims with a +10 offset (i think they are usually +12) and +40 is stock. The centerline of the rim will be sticking out 30mm farther out then stock. 30 mm = 1.2 inches then add 1/2 of the additional width of the new rim. So if you bought 9" wide rims with a +10 offset the rim face would stick out 1.7" farther then stock. (1.2+.5=1.7). 10" wide rim with +10 would be 2.2 inches. (1.2+1.0=2.2) If you want to have the tires stick out farther, you can venture into the 0 offset and -offset, but like I said, I wouldn't if you tow heavy. |
I have 20x9 0 offset 5 inch back spacing with 37s and my tires are right at the edge of my factory flares. It's perfect IMHO
That sounds what I am looking for. My dad has those factory fender flares and they are pretty big so I am going to look at getting this setup. Thanks!
Sorry I missed the fact that you have fender flares. I agree with the 0 offset post from ^^^ there.
