6.7 FX4 Front suspension factory - Ford Powerstroke Diesel Forum
Old 08-09-2012, 05:19 AM
Dont Mess With Texas!
does anyone have a pic of the wheel well that shows the stock springs and shocks? My buddy just bought a 2011 6.7 FX4 and I think it is already leveled but not sure if there is a spacer in there from the factory. just want to see a pic of someones stock front suspension to confirm. thanks
Old 08-09-2012, 10:26 AM
their stock springs are taller than ours by an inch i think. and their wheel wells sits higher as well. I have stock truck with 35 toyo M/T (2010 FX4) and my buddy is running exact same tire and sits like 2" higher than me. Pisses me off, but it's they way they come stock from what i understand. I've been wrong many times before.
Sorry no pic bud. I if i get around one I will snap a pic and post.
Old 08-09-2012, 11:58 AM
Reason I ask is there is like a 3" polyurethane looking spacer on top of his front springs, so if someone with a 2011 can take a pic of their front spring set up on a stock Fx4 I could compare. Maybe someone put a leveling kit on it.
thanks
Old 08-09-2012, 01:17 PM
There should be a polyurethane spacer with or without a level kit on it. If there is a spacer between the poly spring buffer and the top mount there is a kit in there. Keep in mine it could have bigger springs like I have and to look at it you would not know. You can also put a spacer on the bottom mount as well. If it was a F250 the rear would need a F350 3.5" block or a 4" block or the rear would sag. The stock block is 2".
Old 08-09-2012, 03:16 PM
Yeah I know there should be a spacer in there but only like 1" thick right? it is just a seat for the spring? this one in their is glossy black and like 3" thick...
Old 08-10-2012, 05:43 AM
Nobody has a pic of the stock spring and cup mount on their stock fx4?
Old 08-12-2012, 07:02 AM
Your buddies truck could possibly have the camper package my stock fx4 has it and i believe it sits higher in the front than others...but also mine is an F350 srw i dont know if there are many differences in it and a 250
Sent from my DROID RAZR using AutoGuide.Com Free App
Old 08-12-2012, 07:10 AM
see if He has shock extenders daystar and others come with them
it does sound like a coil bushing is bigger than oem ,, your correct the ones I have seen are like an inch or so ,, I have a 3.5" inch on my 06 for an additional 2 inches of lift
Old 08-12-2012, 03:46 PM
I'm kinda new here... just saw this thread.
Picture below taken this afternoon. F250 Lariat FX4 Off-Road with the Camper Package... driver's side front:
Old 09-04-2012, 03:14 PM
ok sorry i got lost in the sauce here... so I have a 2012 250 4x4, will a 2012 250 fx4 sit higher than mine only in the front or in the rear as well...
i honestly would like the truck maybe 1" taller upfront and 2.5 or 3 in the rear, i like my truck with a little rake.
any suggestions if i should by factory blocks and spacers from ford or go with some kit?
thanks guys for help
