Lifted daily driver - Ford Powerstroke Diesel Forum
post #1 of 11 Old 06-05-2012, 12:17 PM Thread Starter
Send a message via AIM to Floridayfz450
Lifted daily driver
I'm going to be picking up a 2012 F250 4x4 this week, and am trying to pick and choose between all the good 4-6" lift set-ups available right now. I am looking to run a 22" wheel with a 37" all terrain tire, due to a lot of highway driving. Falken and BFGoodrich seem to be the only two making an all terrain in that size. Right now the two lift kits I have in mind are the Carli 4.5" or doing the Icon 4.5 lift, but use One Up Industries three link radius arms instead of the radius arm drop brackets and also doing the One Up traction block setup in the rear. Which setup is a better daily driver, doing say 75 miles round trip on the highway to work each day, and towing a toy hauler to the motocross track on the weekends. I appreciate any input, thanks guys.
Floridayfz450 is offline
post #2 of 11 Old 06-05-2012, 12:33 PM
37s will look better with a 6" lift.
What lift you choose mainly depends on how much money you want to spend.
Driving on the hwy you're not going to notice a huge difference between those two lifts.
Andrew010 is offline
post #3 of 11 Old 06-05-2012, 04:11 PM
InMotionJosh's Avatar
Both kits will be nice. I stick with Icon cause that what I have always used and had good luck with. You looking at coil over kits or like the carli pin top?
2013 CCSB Lariat Ultimate
H&S/AmpResearch/FloPro/MBRP/Recon/AFE More To Come
InMotionJosh is offline
post #4 of 11 Old 06-05-2012, 05:29 PM Thread Starter
Thanks for the input, I'm going to stay with a 35" tire on a 22" wheel to make for some more clearance. If I went Carli I would would go with whatever setup Carli recommends. I believe their bilstein setup is valved specific for highway driving? I would go with the Kings if they can valve them specific to my driving style.
post #5 of 11 Old 06-05-2012, 07:04 PM
6.0L Stroker's Avatar
I have the carli backcountry 2.0 with full rear spring upgrade and it rides awesome on the highway. I also run 37 inch trail grapplers with no rubbing on 20 inch bmfs.
2011 F350 CC/SB Bronze and Gold KR tinted windows, spray in bedliner. MBRP 5in filter back with 6in tip and Mini Max. S&B Dry Intake, TGC Dual Stabalizer.
Sold 2004 Ford F-350, cc/lb Lariat, Procomp 6.5 lift with 37/13.5/17 Toyo Mts, Id tuned Ficm, Bully Dog Triple Dog, MBRP all the way back,
6.0L Stroker is offline
post #6 of 11 Old 06-06-2012, 08:12 AM
What kind of mpgs are you guys getting with the 4" and 35's?
bruce65trojan is offline
post #7 of 11 Old 06-06-2012, 04:25 PM
I have the Carli 4.5 Pintop with full rear deaver and King's all around and it rides pretty nice. I would like to be able to ride in the same setup though with the Bilsteins. I'm 98% on highway so I think the ride is better then stock but I think the shock valving could be tweaked a bit to improve the ride on the highway.
I'm running 35" tires and my mpg is around 14 all around and 16 hwy at 65-75mph. I only dropped 1-2 mpg's over the stock mpg's.
Good luck on your lift I think either one will be great.
2011 6.7L, CC, SB, Loaded, LineX bed liner, Weather tech mats, CCR bike carrier, Carli 4.5" 2.5 Pintop, Carli high mount stabilizer, Full spring rear, Fuel Throttle rims, 35" Mickey Thompson ATZs, AMP Steps, Dura Flap Mud flaps with custom weights...
HSrider is offline
post #8 of 11 Old 06-11-2012, 08:14 PM
Skyd Ram's Avatar
Quoted: 78 Post(s)
Both the Backcountry and the Pintop 2.5 kits ride great on the highway. You will be taking 2 steps forward with the ride with either of these kits but the 22" wheels and 35's are going to negate alot of the ride improvement. I run 37's on 17's and although it doesn't look as cool it rides way better and performs in the dirt.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
8LUG Truck Gear
888-886-2480
Find us on Facebook
Skyd Ram is offline
post #9 of 11 Old 06-13-2012, 11:00 AM
35s and 22s really isnt much difference in sidewall ratio compared to stock so that being a sole factor in ride quality is not accurate IMO.
You add a mud tire to anything the ride is going to diminish. I run 35s on 22s and its just fine.
post #10 of 11 Old 06-13-2012, 11:41 AM
Snake's Avatar
Quoted: 46 Post(s)
If you truly want the best ride possible, go with the OUO lift kit and King or Dirt Logic shocks (my understanding is that OUO switched over to the Dirt Logic's, which are great shocks).
Keep in mind that the King's and Dirt Logic's can be built to your specs, and both are great quality.
Back in the day, I was in your shoes with my 2005. The OUO kit was out of my price range so I went with a 8" Rize kit and King coil overs up front, King reservoirs in the back. Five years and 70k miles later I'm glad I did it the way I wanted from the start and didn't cut corners.
Snake is offline
