| 6.7 Exterior Discussion 6.7 Exterior Discussion |
Rim offset
What do I need to know about the offset on after market rims with our trucks?
I am looking at a set that are -12. What dies that mean exactly? Sent from my DROID RAZR using AutoGuide.com App Last edited by LFD132; 03-13-2012 at 04:00 AM. |
Offset
The offset of a wheel is the distance from the mounting surface of the wheel to the true centerline of the rim. A positive offset means the mounting surface of the wheel is positioned in front of the true centerline of the rim / tire assembly. This in effect brings the tire in to the fender well more. Conversely, a negative offset means the mounting surface of the wheel is behind the true centerline of the rim / tire assembly. This will cause the tire to stick out away from the vehicle. To compare the effects of changing the offset and width of your wheels use the Wheel Offset Calculator Wheel Offset Calculator Also read this https://www.rsracing.com/tech-wheel.html Last edited by matty21; 03-10-2012 at 03:17 PM. |
Thank you sir. I'm trying to decide how far the rims will stick out from under the fender wells. Good info thanks
Sent from my DROID RAZR using AutoGuide.com App |
I run +1 a +12 would stick them in 1/2" more.
This is making my head hurt. lol I'm looking at a set of XD rims 20x9 that have a -12 off set. That should make them stick out correct?
Maybe this will help.
![]() Mark |
You first posted a +12 offset that would stick out 1/2" less than a 0 offset. But now your saying -12 that would stick out 1/2" more than a 0 offset. The offsets are in millimeters. The photo in my last post is hard to tell but the tire tread stick out about 1".
This is a pic of my trucks wheels. Tires are 33x12.5x20. On fuel hostages 20x10 -24 offset hope this helps
Yes I did, my apologizes. -12 would be the correct of set I am asking about. Thanks
That looks more like a +24. If it was a -24 and they are 10" wide they would stick out 1.5" more than my 9" +1 offset wheels. Your's don't look like that. But they do look to be .5" less or more than mine. Which at +24 it would be 1" less than mine but add the .5" and your .5" less than mine.
