| 6.7 Exterior Discussion 6.7 Exterior Discussion |
Leveling kit Questions (MPG)
Im thinking of getting a 6.7 and having a leveling kit with 35s put on. What kind of MPG are you getting with the kit put on?
coming to a ford from a 11 Duramax denali |
lost 3 on avg. Went from averaging 17 to about 14
I don't think that you lost 3mpg from the 2" kit, it was the Nitto's that did that, running a MT tire you can lose 2-3-mpg alone.
For the most part a level kit will not change a thing. But the tire will be the mpg killer. Using a good AT tire will help keep the mpg's. Last edited by vlxjim; 01-05-2012 at 08:23 AM. Reason: text |
I was just clarifying to the OP that if MT tires are run it kills the MPG.
I agree that the MT's are the biggest killer. The weight, wind and rolling resistance is greater than an AT. I would get better mileage with my MT's when the tread was worn down than when they were new. I also think that the leveling kit plays a roll. The more air getting under the truck hurts it's efficiency, especially at highway speeds. There is a reason Ford put those massive air dam's on the front of these trucks.
I bought the pro comp 2.5" front leveling kit for my 2012 f250 ccsb. Had it on for 3k miles and hate it! ride is harsher then factory. rode in a truck with icons 2.5" stage 2 and it is sooo noticeably better then factory that it is definitely on my short list of things to do! I did not know anything about lifting trucks and learned the hard way that you get what you pay for!
As far as the MPG difference, I got the same as stock setup 16.2 mpg with the front leveled (it actually sits 1 1/2" higher then the rear) just ordered the rear blocks to fix this! I ordered 20x9 fuel hostages with 35" toyos they are being installed tomorrow with the rear block kit. I will let you know how my mpg adjusts |
stock with 18 rims got 18 mixed driving 35 mickey thompson atz 20 stock rims 2.5 ready lift 14.5
20x9 fuel hostage with 35" toyos I drove 250 miles today reset my fuel economy before I left I got 13.8 on the way to Orlando, installed a S & B intake in orlando and drove back home reset it again and it is reading 14.9 mpg. Not sure how accurate this is as I was watching the mile markers go by slower then the odometer was changing. hope it helps!
