Pretty sure this is the route I'm going. I really wanted to run 22" American force blades with 35" toyo mt on a bus 4.5" lift. Torn between the American force or bmf novikane 8's. Any pics of this size setup would be appreciated! Also some feedback on offset width drivability and if it rubs. Leveled on 35's now just want a little bit higher.
I think In general the 4.5" doesn't play as nice with most 22s cause of the width and back spacing. I know there are s few 22x10 and 22x9s out there but most the common wide 22s have a lot of negative backspace and high wheel scrub (outside turn radius) so require higher lift. You thinking 33s or 35s, 33s would probably be fine, 35s might take trimming on a set of 22s with -40 backspace.
Is there anymore info about this trucks set-up? Front Lift? Backspacing?
Everyone I have spoken to is telling me 22X14 is impossible without rubbing without at least a 6" Lift. My truck is kept in the Garage, I only have 4" of clearance above the cab to clear. And this set-up looks like my only possible solution if I want to have American Forces on my truck.
Rubs at full lock and when I'm backing up. If i took the flares off it probably wouldn't rub.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
