Is your tailget step useless with 37's? - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
 1Likes
post #1 of 12 Old 04-15-2014, 07:45 AM Thread Starter
I'm trying to narrow down my options for a 2015. I plan to lift it about 2-3 inches and put 37's on it. Will the tailgate step be too high to use? Thanks in advance. Anyone have pictures maybe or a height with a tape measure?
Clean-15 is offline
post #2 of 12 Old 04-15-2014, 08:31 AM
I have 4" lift on 35s. I use the ball and the pole to get in the bed. Step is a little to high to be practical. I'm 5'10" for reference.
Brett
2013 F250 CCLB FX4 4" PURE PERFORMANCE
2013 F150 FX4 LEVELED 285'S
2001 F350 7.3 CCLB ZF6
rustyshakelford is offline
post #3 of 12 Old 04-15-2014, 09:34 AM Thread Starter
OK, maybe I should think about the AMP Bedstep since I'm sorter than you
Clean-15 is offline
post #4 of 12 Old 04-15-2014, 10:47 AM
POWERCHOKER
Dantron's Avatar
I like the tailgate step, but I deleted the pole. I find the tailgate step more useful now after adding the 6 inch lift. It would probably be more useful with a 10 inch lift as climbing straight up from the tailgate requires more effort.
Dantron is offline
post #5 of 12 Old 04-16-2014, 01:11 PM
Axis2011KR's Avatar
Quoted: 2 Post(s)
You're gonna need more than 2-3" of lift to clear the 37's...even on stock rims. 4.5" is the minimum recommended lift and that requires trimming still to tuck 37's on most conservative rims.
That being said the tailgate step should still be usable if you're 6'+ pretty easily
2015 F-250 King Ranch 6.7L CC FX-4
Fabtech 10" 4 Link with Coilovers/American Force Vector 22x12/Toyo MT 40x15.50x22
SCT+No Limit+FloPro
2011 F-250 King Ranch 6.7L CC 4x4 sold
H&S+S&B+Open Downpipe
Axis2011KR is offline
post #6 of 12 Old 04-16-2014, 05:14 PM
I run 37s on 3.5 inch ready lift and factory 20s. My tailgate step still works fine for me, but i'm 6'2". You can run 37s on factory rims with 3.5 kit but you will rub on radius arms at full lock. I didnt have to do any trimming at all.
t korkle is offline
post #7 of 12 Old 04-17-2014, 11:10 AM
lowmpg's Avatar
Quoted: 71 Post(s)
Step still works for me, I'm 6' 3"
lowmpg is offline
post #8 of 12 Old 04-18-2014, 08:26 AM
HOUTX01X's Avatar
Quoted: 4 Post(s)
Not true... I had them on with just a leveling kit w/ stock wheels though.
'11 F250 KR
XRT Pro, H&S SX-E turbo kit, NoLimit intake/intercooler
OUO bars/blocks
-EGR,CCV,1993pf
Leveled w/ 35 atII
HOUTX01X is offline
post #9 of 12 Old 04-18-2014, 10:04 AM
CM250's Avatar
I have 6" lift on 37" tires and don't have much of a problem using the tailgate step. I am 5'10" and just use the pole for a little help.
2012 F-250 Lariat
5" Diamond Eye Straight
H&S Mini Maxx
S&B CAI
SkyJacker 6" 4-Link
Bilstein Shocks
Dual Fox Steering Stabilzer
37x13.50x20 Toyo Open Country MT
20x10 XD Strike -24mm offset
AMP Research Power Steps
CM250 is offline
post #10 of 12 Old 04-22-2014, 08:55 AM
Axis2011KR's Avatar
Quoted: 2 Post(s)
Maybe I should have said won't fit without significant rubbing. It will absolutely be rubbing on a 13.5" width tire on stock rims without 4.5" or more lift. I know this because my 35x12.50's rub on stock rims.
SCT+No Limit+FloPro
