Spyder Auto Projector??? - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
 2Likes
post #1 of 29 Old 04-13-2014, 08:21 AM Thread Starter
Anyone running these? Are the true Projectors? Says to run H1 for highs and 9006 for lows. Don't want recon so if been looking around. Not to keen on baking my headlights open either lol
Thanks in advance
Spyder Auto | Ford Super Duty 11-15 Projector Headlights - LEDHalo - DRL - Black - High H1 (Included) - Low 9006 (included)
james_de62 is offline
post #2 of 29 Old 04-13-2014, 01:23 PM
I have them and am disappointed in them, I plan to replace the bulbs soon and that fixes them.
Hazzard is offline
post #3 of 29 Old 04-13-2014, 01:38 PM
POWERCHOKER
Dantron's Avatar
I was debating between Spyder and Recon, but decided with Recon which was a mistake. I would assume they are the same quality, but Recon is more expensive. Either way, they are both halogen projectors, so installing an aftermarket HID kit will improve their performance. Also, Recon's LEDs are replaceable and Spyder's are not. It didn't matter for me in the end because I diconnected the Recon LEDs anyway due to their purple-ish colored hue when lit. I would have got the Spyder's with CCFL halos, instead of the Recon's with CCFL halos if I could do it over again.
Dantron is offline
post #4 of 29 Old 04-14-2014, 03:33 AM
OneTon2011's Avatar
Quoted: 17 Post(s)
I am running those on my, and have had no issues at all with them.
OneTon2011 is offline
post #5 of 29 Old 04-14-2014, 05:58 AM
BigGreen06's Avatar
Quoted: 105 Post(s)
I had the same dilemma, I wanted the projector lights and really wanted to go with Spyder over Recon, mainly because of issues with Recon in the past. However the Spyder projectors weren't in production yet, and so went with Recon. Only problem I've had is the halos and LEDs on the right side light keep failing, already changed the solenoid twice. The left side is the original, no problems.
Work Truck: 2010 F350 KR Oxford
Ford F250 CrewCab SWB 4X4 XLT. Sold
4" MBRP 409 SS Turbo-Back w/ Cat & Muff Delete
SCT Livewire w/ Looney Tunes, Courtesy of Vivian
AirDog 100 from Pure Flow Industries
Accufab Elbow
AFE Stage II W/ PG7 Sold!
Revtek 2.5" Level Kit
Nitto TG From Discount Tire
Smkd LED 3rd Brake & Smkd Mirror Lenses From Stealth Auto
LineX in the Bed
HID Highs/Lows 6000K.
Front & Rear Strobes & Front Dual Talon LED Dash Light, All Whelen;
BigGreen06 is offline
post #6 of 29 Old 04-16-2014, 08:15 AM
barobbin's Avatar
Quoted: 3 Post(s)
how much are the spyders?
barobbin is offline
post #7 of 29 Old 05-11-2014, 05:09 PM Thread Starter
Are the spyder headlights real projectors or they just advertising like they are but just have brighter bulbs? Like do the have the lens and all?
skinny1030 likes this.
post #8 of 29 Old 05-11-2014, 07:02 PM
POWERCHOKER
Dantron's Avatar
Yeah. I disconnected all the LED's. They looked blue+purple while the halos are white. One of my CCFL halos goes out about 15% of the time. I haven't taken a peak what's causing it yet..
Dantron is offline
post #9 of 29 Old 05-11-2014, 07:07 PM
POWERCHOKER
Dantron's Avatar
Yeah. They have projector low-beams with halogen bulbs, reflector hi-beams with halogen bulbs. You'll have a projector line and they look like a crystal ball, but they're not much brighter than standard lights. I recommend you buy an aftermarket HID kit to replace the halogen bulb that lights up the projector.
Dantron is offline
post #10 of 29 Old 05-17-2014, 09:39 AM
matty21's Avatar
they have real projectors, but they are a low quality halogen projector. and yes there is a difference between halogen projectors and HID projectors. they are not meant to have HID'S in them, you can but you'd be better off doing a simple HID projector retrofit like these Bi-xenon FX-R Stage III Kit
Rule of thumb, if your projector takes anything but a D2S,D4S, or the rare D1S bulb. it is not a REAL HID projector and should not have HID's installed in them. the optics will be off and light out put half assed. and/ or melt the housing.
2015 F350 King Ranch
monochrome tuxedo black, every possible option.
Ordered April 30, 2014
Yet to be delivered
2011 F350 KingRanch 6.7L
AFE stage 2 intake
H&S tuner 4" straight pipe
dual 6" MBRP black stacks. DPF, DEF, EGR Delete
ZEX NOS kit with .088 jet
08 Harley Davidson F350
6" lift with 36x15.50x20's
spartan tuned and deleted.
matty21 is offline
