Level the rear to the front - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 4 Old 04-07-2014, 04:12 PM Thread Starter
Hi there, I was wanting to level out my 14' 6.7 crew cab fx4 and i thought about just lowering the rear to match the front instead of raising the front? anyone ever do this? or is just just easier to raise the front and call it a day?
also, does anyone have the height of their truck with 35" tires and a 2.5" leveling kit? I am under some size constraints with my garage is the reason for wanting to lower the rear to match the stock front.
Thanks!
QCGA6.7 is offline
post #2 of 4 Old 04-08-2014, 03:39 PM
RJC2's Avatar
Quoted: 354 Post(s)
There's a part that you can put on your rear shackles to give it a better ride. It supposedly lowers the trucks rear a bit. I think they are called Velvet Ride Shackles. I'm considering them myself as I have a spinal cord injury and could use a better ride without having to climb as high to get in the truck.
Maybe someone that has them could comment...
2017 F350 CCSB King Ranch Ultimate 6.7
2002 F250 ECLB, XLT, 7.3 PSD, 4X4, Auto, TW 6pos. Tuner, 4" SS Exhaust, Britebox, EZ Down tailgate assist, Rear Air Bags, 6.0 trans cooler, Wicked Wheel 2, Corey's HPX, Dieselsite Water pump w/built-in filter, 203 degree thermostat, Max A/C assist, Oil drain valve, Non EBV pedestal & Flange, S.S. bellowed up pipes, Dieselsite Lifetime Rad. hoses & Intercooler hoses, New oil cooler, CTS Insight monitor,
RJC2 is offline
post #3 of 4 Old 04-08-2014, 03:43 PM
STX79's Avatar
F250 or F350? If F350 is it SRW or DWR?
2014 F350 SRW Platinum, Ranch Hand bumpers, AMP Steps, BDS 2" leveling kit, Bilstein 5100 Shocks, 35x12.50R20 Toyo Mud Terrains.
STX79 is offline
post #4 of 4 Old 04-09-2014, 03:09 PM
Cheap6.7's Avatar
I have 325/65/20 on 2 1/2 leveling kit with cab lights and it fits just under 7ft opening
Buy American!
Cheap6.7 is offline
