Not sure which way to go - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 3 Old 04-02-2014, 04:08 PM Thread Starter
I_AM_RP3's Avatar
Hey y'all, hopefully someone here can help. I've decided to lift my truck finally. I have kicked the idea around for a while and initially had my mind made up on the BDS 4" lift with rear block, dual steering stabilizer and Fox 2.0 shocks. Now that its time to pull the trigger, I'm starting to consider the 6" kit with their springs and the other options previously mentioned. I'm going with 35x12.50x20" tires which 4" will be plenty enough to clear. Anyone have this same internal dilemma? If so which way did you go? And why? Also, will a 6" lift make my truck too tall to hook up to a 5th wheel TT? Thanks in advance for the feedback.
V/R,
Robert
I_AM_RP3 is offline
post #2 of 3 Old 04-05-2014, 06:05 PM Thread Starter
I_AM_RP3's Avatar
Well I ordered the BDS 4" lift with Fox 2.0 shocks. Hope it rides good. I figured that will be tall enough since I plan to get a 5th wheel TT soon.
I_AM_RP3 is offline
post #3 of 3 Old 04-05-2014, 06:33 PM
E99F350Stroker's Avatar
Post some pics when you get it on, I think that it will look great.
Jordan
*Sold* Early 99 F-350 dually 4x4 6spd 7.3
*Sold 2000 F-250 4x4 ATS auto 7.3
1996 Dodge 2500 4x4 speed, 12 valve cummins, 283000, stock
E99F350Stroker is offline
