2011 rear springs - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 21 Old 03-12-2014, 08:44 PM Thread Starter
andys08's Avatar
2011 rear springs
Okay I need advice on rear springs I have a 2011 f250 with the icon stage one leveling kit the rear is still stock with air bags for towing. I was going to buy 4in rear blocks to make it sit level but I really would like to buy a whole new set of spring that would raise to rear of the truck so that I can remove all blocks and still sit level. Anyone know about this. Thank you in advance
2004 6.0 6spd,475hp southbend clutch,sct livewire custom tunes done by brians truck shop,5in straight, leveling kit ,egr delete,traction bars,arp studs. (Sold)
2011 6.7 lariat ccsb tinted,air bags with daystar craddle,Titan fuel tank, mini max with custom mount,5th wheel hitch,hids,icon 4.5in lift in front and dealers full leafs in rear,2wd valence,stock lights pulled apart and painted, all other lights tinted,
andys08 is offline
post #2 of 21 Old 03-12-2014, 08:59 PM
Most full spring packs will reduce your payload. That will force you to retain the airbags unless you use carli long travel bags or a daystar cradle. Cheaper option is to keep the 2" 250 block and add a mini pack from carli. That would give you some lift without diminishing your payload to much. If you go that route, get the daystar cradles for $70 and your good to go
If not, get the carli springs
Brett
2013 F250 CCLB FX4 4" PURE PERFORMANCE
2013 F150 FX4 LEVELED 285'S
2001 F350 7.3 CCLB ZF6
rustyshakelford is offline
post #3 of 21 Old 03-14-2014, 09:27 AM
OCVeloMan's Avatar
Quoted: 158 Post(s)
Garage
As Brett Mentioned, we sell a full replacement leaf spring pack for the rear that sits about .5" higher than a stock F350 which is about 2" taller than your truck sits in the rear. These springs eliminate the blocks but will reduce the payload which is a non-issue given you're running airbags to make up capacity for when you're hauling. The only issue would be a discrepancy in rear shock choice as you need way more than the factory shock to control the spring rate differentiation in our full progressive leaf springs. What are you running in the rear? Also, the Daystar cradles to allow for droop travel were another awesome idea so i'll +1 that!
OCVeloMan is offline
post #4 of 21 Old 03-14-2014, 04:29 PM Thread Starter
andys08's Avatar
The rear is completely stock the air bags mount to the axle so I don't think the cradle would work unless I'm missing something. So if I use your springs and remove the block would that move the axle or keep it centered in the wheel well
andys08 is offline
post #5 of 21 Old 03-17-2014, 09:13 AM
OCVeloMan's Avatar
Quoted: 158 Post(s)
Garage
You would need to swap the lower bag mount you currently have for a cradle mount (will likely work with your bags if they have steel bottom plate), then replace the springs with ours which will eliminate your block and improve the ride and you'd need to run one of our custom tuned shocks to control the springs.
post #6 of 21 Old 03-18-2014, 08:34 PM Thread Starter
andys08's Avatar
What kind of shocks we talking $
andys08 is offline
post #7 of 21 Old 03-20-2014, 07:17 PM Thread Starter
andys08's Avatar
Any options that I don't have to change my bags
andys08 is offline
post #8 of 21 Old 03-26-2014, 08:12 PM Thread Starter
andys08's Avatar
Any advice
andys08 is offline
post #9 of 21 Old 03-27-2014, 08:45 AM
OCVeloMan's Avatar
Quoted: 158 Post(s)
Garage
I would recommend a commuter kit to go with it. $2,830 for the full leveling kit with Fox 2.0's and the full deaver leafs to work with the bags and cradle mount.
You're not going to get a better ride out of a bag that increases in rate exponentially through travel and locks your rear axle to 4-5" of travel.
post #10 of 21 Old 03-30-2014, 06:13 PM
How do the daystar cradles work? Will they work with air lift air bags system?
sxr_nathan is offline
