Radio antenna - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 2 Old 03-11-2014, 06:35 PM Thread Starter
automoto's Avatar
Quoted: 13 Post(s)
Radio antenna
I just bought a 12' f350 lariat. The radio antenna mast seems to be broken. The thin metal wire that is wrapped around the plastic sheath has come undone and hangs halfway down. Does anyone know what this wire is for, and can i cut the wire? Truck has hd radio/sirius/nav. Thanks in advance.
automoto is offline
post #2 of 2 Old 03-11-2014, 06:38 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Im gonna assume that little wire is the actual antenna so Im gonna figure cutting it will affect your signal. Im may be wrong..
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
