Guys who have put their own lift kits on - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 8 Old 02-24-2014, 11:06 AM Thread Starter
Quoted: 2 Post(s)
2011 F250
Track bar bolt Help 30MM one for the drop down bracket.
Need some input on how to get the track bar bolt loose. I have tried and tried to get it off with my impact gun and it will not move. I tried a breaker bar still nothing. I have let it soak with PB blaster on it as well.
Thanks for your input
2011 F250 6.7 3.55 gears
20" wheels,
Tonneau cover,
Chrome mirror covers and door handles,
Line-X bed liner,
LED grille lights amber,
EZ-down tailgate,
Tinted windows,
3.5"Ready lift kit
Amp steps
Bigtwinharley is offline
post #2 of 8 Old 02-24-2014, 03:27 PM
smokin_h's Avatar
The 30mm bolts suck.....I used a 3/4 breaker bar and a 3/4 impact socket w/ a 4' cheater to break it loose....I ended up jumping on it to break it free....im 6-4 260 so it takes a lot.....re-torqing is worse than breaking them loose just an fyi--I forget the torq specs but ur eyes will be bugging to even get close to the specs. Be glad you arent doing the 30mm ones on the front of the rear leaf springs....just as tight and no room to get to them esp on the driver side! Good luck!!!
2012 F250 King Ranch
smokin_h is offline
post #3 of 8 Old 02-24-2014, 03:40 PM
I put mine on like a year ago I just can't remember any bolts being that hard. The hardest for me was the pittman arm nut and getting the arm off.
Sent from AutoGuide.com App
2012 F250- 4.5in. lift, 24x12 rockstar II's painted tuxedo black, 37x13.50x24 M16's, KEM race tunes, 5in. exhaust, and much more.
DillonC is offline
post #4 of 8 Old 02-25-2014, 10:16 AM
Quoted: 15 Post(s)
Yeah I don't remember anything super tight...and I just did mine around two weeks ago. But I didn't take the Pitman off...I just worked around it.
2016 Cadillac Escalade ESV
2014 Mercedes E350 Sport
2012 F350 6.7L CCLB Lariat Ultimate SOLD
2007 F350 6.0L CCLB XL FX4
2010 F350 6.4L CCLB DRW XLT SOLD
1970 FORD TORINO COBRA 429
fosterelli is offline
post #5 of 8 Old 02-25-2014, 10:44 AM
That's because yours didn't come with a drop pittman arm to replace the stock one, but yours did come with the drop trac bar bracket. That's the one they're talking about.
I'll have to look at mine again though, I don't remember a bolt that big.
DillonC is offline
post #6 of 8 Old 02-25-2014, 12:07 PM
Quoted: 15 Post(s)
I believe the OP is installing the same kit as mine. The Pitman arm & steering drag link connection is suggested to be removed for clearance to remove upper track bar bolts (3) and install the drop bracket (on my kit). I left it alone and just worked around it.
The 30mm is the track bar frame bracket connection...wasn't horribly tight for me...but I accessed it from the driver's wheel well I think.
post #7 of 8 Old 02-25-2014, 01:06 PM
Track Bar bolt was a beast. Just installed my pure kit. Used a 3/4" breaker bar with at least a 4' heavy pipe to break it free. Tried heating it with an oxy/acetylene torch and impact it off with no luck. And my truck only has 5500mi.
2012 CCLB F250 Lariat 4x4 6.7L
Rigid Industries 20" E-Series-Husky Liners-S&B Intake
Pure Performance 4" Triple Threat-PMF Dual Steering Stabilizer-Method NV-315 70R18 Toyo M/Ts
5-0stank is offline
post #8 of 8 Old 03-01-2014, 09:45 AM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
I just did a 2011 4.5" kit. All the bolts zipped right out with my IR 1/2" impact. Only thing that took some time was removing the pitman arm from the sector shaft.
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
