Aftermarket Running Boards / Nerf Bars? - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 9 Old 02-23-2014, 02:43 PM Thread Starter
Farmer_6.7's Avatar
Does anyone know if ionic running boards are very high quality? What about go rhino? I am looking to switch the boards on my truck as I don't like the black plastic ones.
I am interested in the following boards:
Ionic-Gladiator Brite Running Boards
5" Railway Chrome Running Boards Ford F250/350/450/550 SD Super Cab 1999-2014
Go Rhino 5" O.E. Xtreme Oval Chrome Side Bars Ford F250/350/450/550 SD Super Cab 1999-2014
Any suggestions/experience would be appreciated. I can't see spending over a grand on the factory ford boards.
Thanks!
2011 F-250 - Lariat, 4x4, ECSB, Vermillion Red
Mods - H&S Mini Maxx, 5" Flo-Pro DP Back, 2" Leveling Kit, 305/55R20 Toyo ATII's
Farmer_6.7 is offline
post #2 of 9 Old 02-23-2014, 03:52 PM
Running Boards
I have a set of AMP Power steps that came off my 2012 F250 CC short bed that I will Sell for $600. Truck had 4100 miles on it and I took them off to trade it in on a dually. Have a Roll N Lock bedcover also for sale $600
Shayc5 is offline
post #3 of 9 Old 02-23-2014, 04:08 PM Thread Starter
Farmer_6.7's Avatar
Where are you located? (may be interested in the roll n lock, as my truck is a supercab and the boards would not work)
post #4 of 9 Old 02-23-2014, 04:45 PM
fordtrix's Avatar
Do the steps have all the wiring and instructions? Where are you located?
2013 F250 Lariat CCSB - Firestone Ride Rite, Bakflip F1, B&W 5th Wheel Hitch, Carli 2.5" with track bar, Fuel Maverick 20x9, Toyo MT 35x12.5, Bushwhacker Extend-A-Fender, Weathertech Mats, Recon 3rd Brake and Mirror Lights, PTM Mirror Caps
2013 Crossroads Elevation 3912 - Loaded
fordtrix is offline
post #5 of 9 Old 02-23-2014, 05:02 PM
AMP's and Roll N Lock
They are located in Huntsville, Alabama 35811. Huntsville is at the very top of Alabama.
The steps have all Wiring and instructions, hardware, LED lights.
Shayc5 is offline
post #6 of 9 Old 02-24-2014, 06:01 AM
SHOWOFF's Avatar
Shayc5, I sent you a PM.
2014 F250 Plati
SEMA 2K15
Krazy Nikel
SHOWOFF is offline
post #7 of 9 Old 02-24-2014, 08:22 AM
Alberta Advantage's Avatar
Quoted: 20 Post(s)
You can look on here or Craigslist and get a pair of OEM steps for pretty cheap. A lot of people take them off to install AMP or other aftermarket steps. I sold my OEM steps for $300. I bought NFab steps but I wouldn't recommend them. The finish/powder coat is crap and the steps are slippery when they're wet and are too small for a workbook to fit in the step.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #8 of 9 Old 02-24-2014, 05:42 PM
mor4wd's Avatar
Plus 1 for AMP Research or BestTop Powerboards. I have the BestTops and they are one of the greatest things I added to the truck. They actually come down to a usable height (I use em every time I get in the truck and I'm 6'2"), plus they go up and out of the way so you won't hang em up on something (which is why I got them in the first place).
2011 F350 Lariat SRW Crew Cab Long Bed 4x4 6.7 H&S Mini Maxx DPF Delete EGR Delete running 265/70/19.5's
Originally Posted by magzne1 View Post
Chevy comercials are like OBAMA, ALL B.S. over promise and under deliver
Originally Posted by trevor73402 View Post
This stuff isn't as simple as tuning your TiVo to record your Jerry Springer re-runs while your out cruising Wal-mart parking lot for transexual hookers.
mor4wd is offline
post #9 of 9 Old 02-25-2014, 12:27 AM
Quoted: 20 Post(s)
If you live in a cold climate with snow and ice, be prepared for power steps like Amp or Best Top to get hung up when ice gets jammed and wedged in the step mechanism/brackets and hinges. There's lots of high end SUVs here with power running boards that are all stuck in the open position until it warms up. Makes me wonder if the motor is still trying to continually work each door cycle burning itself out. The power boards can also flap or flutter in the wind. I also don't like how there is only one motor per step. The side with the motor usually hugs the step close to the pinch welds for that clean unnoticeable look while the other side has no motor and hangs noticeably lower. If you don't account for this, your steps look like they aren't level/crappy install done. The best steps I've used are the OEM ones. Large enough to get good traction in any shoe or boot and very strong.
Putco Window Visors
Line-X
Bak Flip F1
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
4" Solstice Prime
Truck Bed Lights
