Recon Mirror Lights - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 6 Old 02-13-2014, 06:23 AM Thread Starter
fordtrix's Avatar
Recon Mirror Lights
So, first of all, I have read all the crap about recon sucking. Still, there are very few light options out there, so I ordered their smoked 3rd break light and mirror lights. I didn't mind risking these as much since they were relatively cheap.
My 3rd break light is pretty solid and looks great. Connection was good, it's been about 2 months and still good to go.
Last night I installed the mirror lights. Oh my gawwwwwwdddd.. Crappiest connections ever I couldn't push one in all the way or it wouldn't work, or out all the way, so I got it in snug, then used electrical tape. Did the same on the other side. Just a very poor design you can tell.
That being said, if they continue working, I think they look far better than stock, so that's a plus. I saved all my old lights so worse case scenario I just go back.
I've read the horror stories and couldn't help but laugh (and be slightly annoyed) when I installed the mirror lights last night.
2013 F250 Lariat CCSB - Firestone Ride Rite, Bakflip F1, B&W 5th Wheel Hitch, Carli 2.5" with track bar, Fuel Maverick 20x9, Toyo MT 35x12.5, Bushwhacker Extend-A-Fender, Weathertech Mats, Recon 3rd Brake and Mirror Lights, PTM Mirror Caps
2013 Crossroads Elevation 3912 - Loaded
fordtrix is offline
post #2 of 6 Old 02-13-2014, 06:35 AM
Chug-a-lug!!!
colberjs's Avatar
Quoted: 11 Post(s)
Did you use the electrical tape in a spot where it would be visible?
I have Recons all the way around my truck (except for the headlights because I didn't feel like taking out a second mortgage to buy them) and the mirror lights were the only ones I had trouble installing but I did get them in eventually without any modifications. So far they all still work. Been over 2 years.
Jesse
2011 F-250 Fx4 CrewCab Short Bed
Bone Stock............Or Is It?
colberjs is offline
post #3 of 6 Old 02-13-2014, 07:01 AM Thread Starter
fordtrix's Avatar
I just used electrical tape where they plug in (at the connectors) To make sure they stay secure, because they just kind of press in, no real locking mechanism or anything.
I think they will probably be fine, I just couldn't help but laugh and get a good understanding of what some people were talking about regarding their lack of quality. I'm a quality manager for a living, so I am a bit nit picky about certain things.
fordtrix is offline
post #4 of 6 Old 02-13-2014, 05:07 PM
DSL_PWR's Avatar
Quoted: 9 Post(s)
I am just going to have the local paint shop 'tint' mine so I don't have to change them out. Close in cost but still stock.
DSL_PWR is offline
post #5 of 6 Old 02-13-2014, 07:29 PM
POWERCHOKER
Dantron's Avatar
Yeah same exact thing happened to me with my second pair of Recon mirror lights. I just kept fiddling with the connectors until they would light up when properly installed. Good news is that they have worked fine ever since.
Dantron is offline
post #6 of 6 Old 02-14-2014, 08:38 AM
I just got the recon mirror light installed on my truck.
What a piece. It uses stock light socket to connect the mirror lights. There isn't much room to shove all of the wiring and socket behind the light assembly. Also worried about it being exposed to the weather elements since the socket is sitting outside of the light assembly
Also the fitment of the assembly isn't nearly up to par with the stock. There is a slight gap on the end of the mirror on both side. I've tried to push it in without much luck
I think i may take them out and put some electrical tape around the connection point to secure it bit better in the near future
ph00ny is offline
