Leveling Kit back to stock. - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 14 Old 01-20-2014, 08:49 AM Thread Starter
Quoted: 7 Post(s)
My 2011 Crew cab f250 has a leveling kit on front and I installed f350 blocks in the rear to get the back all matched up. I just aint much of a lift guy and I want to put it back to stock height but I'm no sure what all itll take up front. What is removed on the leveling kits up front that is OEM? If some of yall don't mind helping me figure it out. I can provide pics etc. I also have some 35x12.50x20 AMP MT tires and Black XD wheels, I am debating on parting ways with and getting a narrower tire/wheel setup.
Juggernaut_7 is offline
post #2 of 14 Old 01-21-2014, 05:09 AM
DSL_PWR's Avatar
Quoted: 9 Post(s)
What kind of leveling kit? That will determine what parts need to come off. Could be just spacers, maybe a trac bar bracket, etc.
Have a 4WD shop around you? They will usually remove them pretty cheap.
DSL_PWR is offline
post #3 of 14 Old 01-23-2014, 01:38 PM
cjf250sd11's Avatar
Quoted: 2 Post(s)
Appears they added a spacer similar to a ICON TEI spacer as circled. You have the stock spring/shock it appears as well. Remove that spacer and swap out your rear block....DONE.
2014 F250 4x4 Platinum, Black Tuxedo Carli Commuter Fox 2.0 & Steering Damp, PP 4-link, Fuel Maverick 20x10 - 5" BS, Toyo Open Cntry AT II 35x12.50, Recon LED Smoked Tails, 3rd Brake, Cab & Mirror Lights
SOLD 2011 Super Duty F250 6.7L - Lariat Ultimate 4x4, Black Tuxedo, Icon 2.5" Lift, Bilstein 5100's, 35x12.50 Pro Comp Xtreme Terrain on 20x9 BMF Novakane 8's.
cjf250sd11 is offline
post #4 of 14 Old 01-23-2014, 01:43 PM
Don't you worry about it
strokinpower's Avatar
Quoted: 277 Post(s)
Yea just remove the spacer on the bottom of the coil but you will need to get shorter bolts to bolt the spring cup back on the bottom.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
post #5 of 14 Old 01-23-2014, 02:01 PM Thread Starter
Quoted: 7 Post(s)
That's what I was thinking. If anybody has a oem front setup, if you could show a pic. I'd appreciate it.
post #6 of 14 Old 01-24-2014, 05:59 PM Thread Starter
Quoted: 7 Post(s)
I think this is a rough country spacer. I read their instructions and it says you have to remove factory spacer when installing this, so if that's the case I wont be able to just remove the spacer. Been trying to find a pic of a stock setup so I know for sure what I need before I start in doing the job.
post #7 of 14 Old 01-24-2014, 06:04 PM
BK1977's Avatar
I'll bet you could offer to trade someone and have plenty of offers
Sent from AutoGuide.com App
03 f-250 CCLB FX4 6.0. H-11 studs, egr delete, swamps 58 v ficm, sct sf3, autometer ultralight boost, pyro and trans temp. Complete 08 bed. And a few other things
BK1977 is offline
post #8 of 14 Old 01-24-2014, 06:11 PM Thread Starter
Quoted: 7 Post(s)
I wouldn't mind trading straight across for a stock front end setup, but we would both have our trucks apart waiting on stuff to come in and that's what im trying to avoid. I have my stock rear blocks and u bolts. So ill just sell the F350 blocks and u bolts id imagine
post #9 of 14 Old 01-25-2014, 04:16 AM
Quoted: 277 Post(s)
There should be no factory spacer on the front. You just remove the aftermarket spacer and bolt the spring cup back down.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
post #10 of 14 Old 01-25-2014, 06:02 AM Thread Starter
Quoted: 7 Post(s)
Ok. Thanks. Ill just snatch a oem bolt for spring cup and try it out.
