Icon vs Pure Performance vs Carli - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
 1Likes
post #1 of 58 Old 01-03-2014, 07:55 AM Thread Starter
Help me decide which 4/4.5" kit please
Looking into the bottom level kits they offer. I like that the carli has brake lines with it and also the crossmember, but it seems like I can get an icon kit to my door for just under 2k.
Edit: here's another question. Any tires in between a 35 and 37 for a 20" wheel? One thing I'm worried about w/ a 4.5" kit is that a 35 will look too small, but I'm not sure I want a 37 either.
2012 CCLB F250 Lariat 4x4 6.7L
Rigid Industries 20" E-Series-Husky Liners-S&B Intake
Pure Performance 4" Triple Threat-PMF Dual Steering Stabilizer-Method NV-315 70R18 Toyo M/Ts
5-0stank is offline
post #2 of 58 Old 01-03-2014, 08:42 AM
layson's Avatar
Quoted: 83 Post(s)
I am a big fan of Icon. They are nice riding kits.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #3 of 58 Old 01-03-2014, 10:20 AM
OCVeloMan's Avatar
Quoted: 183 Post(s)
Garage
At under 2K you're getting blocks in the rear. Ours comes with a progressive add-a-pack so it's not really comparing apples to apples. If you were to pull our add-a-pack and add in a block, I'm sure ours would be the same price, if not a tad cheaper. You will be sacrificing ride quality to make that swap, though!
OCVeloMan is offline
post #4 of 58 Old 01-03-2014, 11:03 AM
sprksonu's Avatar
Carli FTW. You get what you pay for. Wanna look cool sure get the icon, but if you wanna look cool, be able to use the lift kit and ride nice on top of it get the Carli and never look back. I have been 4ft off the ground in a SD with the Carli kit and lemme tell ya it's a blast.
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #5 of 58 Old 01-06-2014, 01:07 PM
Quoted: 35 Post(s)
Like Dan mentioned you will definitely see a ride improvement from the Carli add a packs over a block. Not to mention the potential for future shock upgrades with the Carli kit.
Free shipping on Carli Suspension to the US and Canada!
424-241-3252
CJCOffRoad is offline
post #6 of 58 Old 01-06-2014, 01:58 PM
Skyd Ram's Avatar
Quoted: 150 Post(s)
I would say for the couple extra hundred bucks it is well worth it to go with the Carli Starter. You get the cross member, brake lines, and add a packs. The add a pack will ride far better and control wheel hop as opposed to just running a tall block.
If that is still too far our for your budget you could do the new Pure 4.5" Triple Threat with a set of 5100's for under $2200 shipped. Again, you are getting brake lines, and an add a pack/ short block combo as opposed a tall block.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
888-886-2480
Skyd Ram is online now
post #7 of 58 Old 01-07-2014, 05:09 AM
1stnlast59's Avatar
How do the PP coils ride. They look progressive rate but thought I'd ask.
1stnlast59 is offline
post #8 of 58 Old 01-07-2014, 06:52 AM
Skyd Ram's Avatar
Quoted: 150 Post(s)
The Pure coils have a lower rate than the Icon's and are pretty close to the Carli's. Carli uses a single rate coil so it's hard to make a direct comparison.
888-886-2480
post #9 of 58 Old 01-07-2014, 07:42 AM
layson's Avatar
Quoted: 83 Post(s)
I actually feel the opposite and that the Carli kit is for looking cool.... LOL
Quote of the Day:
layson is offline
post #10 of 58 Old 01-07-2014, 07:58 AM
OCVeloMan's Avatar
Quoted: 183 Post(s)
Garage
Don't be angry because our systems look as good as they ride!
The Following User Says Thank You to OCVeloMan For This Useful Post:
sprksonu (01-07-2014)
