Rear suspension problem - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 10 Old 12-11-2013, 06:43 PM Thread Starter
andys08's Avatar
Finally bought my leveling kit and went to measure the rear end to see how much lift I wanted to add for some reason the driver rear is an inch and half lower than passenger. Anyone else have this issue
2004 6.0 6spd,475hp southbend clutch,sct livewire custom tunes done by brians truck shop,5in straight, leveling kit ,egr delete,traction bars,arp studs. (Sold)
2011 6.7 lariat ccsb tinted,air bags with daystar craddle,Titan fuel tank, mini max with custom mount,5th wheel hitch,hids,icon 4.5in lift in front and dealers full leafs in rear,2wd valence,stock lights pulled apart and painted, all other lights tinted,
andys08 is offline
post #2 of 10 Old 12-11-2013, 07:34 PM
sometimes u just have to drive it a day or two to let it settle back down to it's new baseline height.
btw, my lift was off from one side to the next, front vs rear as well and now it's only off by 1/4 of an inch at most. before it used to be at most 1.75" difference
gigabit is offline
post #3 of 10 Old 12-11-2013, 08:02 PM
Hope all that have experienced this will chime in. I have a buddy thats got the same problem and don't know what to do to fix it.
KENNY
2013 F250 Platinum Tuxedo Black
3.5" Ready Lift
Firestone Air Bags
20x10 BMF Novacane DMB
35x12.50R20 Toyo MT
kennyketten is offline
post #4 of 10 Old 12-12-2013, 08:36 AM
Skyd Ram's Avatar
Quoted: 150 Post(s)
Almost all Super Duties sit 1/2" to 1" low on the drivers side right of the dealership lot. Most guys never notice until they start measuring stuff after the install suspension mods. My stock 2011 sits 1 inch low on the drivers side and to help a customer believe me after he lifted his truck I measured every 2013 on the Ford lot by our shop. the closest to level was one truck that was only 1/2" low on the drivers side but remember this is with nearly zero fuel in the tank. Add another 200 pounds of fuel to the tank on the drivers side and you will see it drop another 1/4"+.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
888-886-2480
Skyd Ram is offline
post #5 of 10 Old 12-12-2013, 04:12 PM Thread Starter
andys08's Avatar
The front is exactly the same just the rear I have a 50 gal Titan Tank with 1/4 tank now and the driver is still 1 1/2in off seems like a lot. I have air bags but all the air is out
andys08 is offline
post #6 of 10 Old 12-12-2013, 05:57 PM
That is a lot,,,,something is a little off there. I have airbags too, I keep them on 0 psi. when not towing {even though you are not suppose too} because the ride is much smoother. Mine is only 1/2" off down on driver side like yours. Never really noticed it before but now that I know it, it seems like I notice it all the time now and starting to aggravate me
I'm a little perfectionist when it comes to my truck
KENNY
3.5" Ready Lift
Firestone Air Bags
35x12.50R20 Toyo MT
post #7 of 10 Old 12-13-2013, 03:39 PM
salnazzaro's Avatar
Quoted: 25 Post(s)
Same here, drives me nuts! Didn't notice until I was measuring after my leveling kit and rear blocks were installed. I see it no matter what now and think it looks horrible yet everyone else thinks I'm crazy and doesn't notice it!
2015 f350 cclb platinum...5% tint, Anzo smoked mirror lights, recon clear cabs, tgc 2.5" spacers, carli adjustable track bar, icon 5" rear blocks, Firestone riderites, B&W goosneck, line x, rancho 7000s, Fuel Mavericks wrapped in Toyo MT's, No Limit stage 2 cold air intake, 4" flo pro straight pipe, Sct w gearhead tunes, hideaway LEDs
salnazzaro is offline
post #8 of 10 Old 12-13-2013, 04:03 PM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
the steering colum the fuel tank and you sit on the driver side while driving thats a lot of extra weight on the driver side.
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx custom tuned, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Lighting, No Limit S2 Intake, Tinted, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
post #9 of 10 Old 12-13-2013, 04:09 PM
salnazzaro's Avatar
Quoted: 25 Post(s)
^ that's what my mechanic said as well that there's a lot more weight on the drivers side
post #10 of 10 Old 12-13-2013, 08:15 PM Thread Starter
andys08's Avatar
No obvious issues drives me nets any ideas
andys08 is offline
