2011 rear springs - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 8 Old 10-25-2013, 01:11 PM Thread Starter
LFD132's Avatar
Quoted: 3 Post(s)
2011 rear springs
Can someone who has 2011 f350 4x4 with the camper package take a picture of your rear spring set up? I need to see exactly what springs i need to make my f250 the same. Thanks
Sent from AutoGuide.com App
[SIGPIC][SIGPIC]2013 F250 FX4
LFD132 is offline
post #2 of 8 Old 10-27-2013, 11:08 AM
99powerstroke62's Avatar
Quoted: 56 Post(s)
I'll help ya out.
It'll be this afternoon tho
Tyler
2015 F250 CCSB Lariat- tuned/deleted
2011 Wilma F350 ECSB Lariat-
2006 Black Magic RCLB XL- In pieces
99powerstroke62 is offline
post #3 of 8 Old 10-27-2013, 12:03 PM Thread Starter
LFD132's Avatar
Quoted: 3 Post(s)
Thanks
LFD132 is offline
post #4 of 8 Old 10-28-2013, 04:50 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Subscribed!
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #5 of 8 Old 10-28-2013, 06:19 AM
Quoted: 56 Post(s)
Im a day late guys, I work third shift and I have to go in at 1030 on Sundays. So must my day is spent sleeping.
Walked outta work and realized I forgot to snap some pictures.
If you need better ones or different angles let me know.
Tyler
post #6 of 8 Old 10-28-2013, 06:40 AM Thread Starter
LFD132's Avatar
Quoted: 3 Post(s)
Thanks man, guess there really is no difference between the 250 and 350 except for a taller block. Just ordered an extra spring from general spring and i have a set of 350 blocks. Gutters I'll see How that works. Thanks fire taking the time to take pics.
LFD132 is offline
post #7 of 8 Old 10-28-2013, 01:13 PM
Skyd Ram's Avatar
Quoted: 117 Post(s)
A standard F250 will have the shorter 2" block, lower overload, and 2 leaf main pack.
F350 Camper Package will have the taller 3 5/8" block, lower overload, 2 leaf main pack, and upper overloads with contact pads on the frame as well as a rear sway bar.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
888-886-2480
Skyd Ram is offline
post #8 of 8 Old 10-28-2013, 01:21 PM Thread Starter
LFD132's Avatar
Quoted: 3 Post(s)
Thanks, i am so missing my 2011. I just put that 4.5 starter kit i bought from you on there.
LFD132 is offline
