how in the ????? - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 6 Old 08-28-2013, 05:43 PM Thread Starter
how in the ?????
Ok may be a dumb question here but the other night got stopped by a dot officer because my marker light on my mirror was out. no ticket or nothing but a warning. Now i looked at it and dont wanna just yank it apart but how the hell do you change the bulb in the mirror??? sorry if its a dumb question but any help/pics would be appreciated
2011 F350 DRW lariat Spartan tuned, 4" straight piped exhaust,afe stage 2 CAI,SDP egr delete and more coming
Sold 12 ram 2500 and dont miss it!!!
E99 F350 7.3L parts on the way
skinnysfd is offline
post #2 of 6 Old 08-28-2013, 05:54 PM
IA Farmer's Avatar
Tilt the mirror glass inward toward the truck and then up as far as it will go. Get a long flat screwdriver and there is a tab that you push and the lens cover will pop out and you can access the bulb. I replaced mine with recon in about 5 minutes for both sides.
2013 F-350 CCSB Platinum
2010 F-250 CCSB Cabelas Edition - Sold
IA Farmer is offline
post #3 of 6 Old 08-28-2013, 05:56 PM Thread Starter
sweet thanks for the help ill get her changed out. dont know what part of iowa ur in but the dot in the nw area here is beign real picky lately. just had a buddy who drives semi get a ticket for his seatbelt beign to loose!!
post #4 of 6 Old 08-29-2013, 01:56 AM
IA Farmer's Avatar
I live just outside of Ames. We also run a seed dealership and often delivery seed on a 32 foot gooseneck. My cousin has a 2013 F250 and got pulled over for not having clearance lights, the dot officer said that anytime the total length of your vehicle exceeds 32 feet you become regulated like a commercial vehicle and are required to have clearance lights, safety triangles and a fire extinguisher. I still need to look into this to see if she knew what she was talking about. Luckily only a warning. Good luck fixing your mirror light.
Sent from AutoGuide.com App
post #5 of 6 Old 08-29-2013, 02:57 AM Thread Starter
Yeah I think hes right as well as no wondow tint whatsoever on ur front windows windsheild etc.. also need to have a yearly inspection sticker in most cases a cdl class no air brakes minimum and the list goes on and on . I actually have a friend who is a dot officer and he flat out told me depends on who stops ya because the book is so big they dont even know all the rules . I had to up my registration on all my trucks a few years back to a minimum of 15 ton and that way they said im legal to pull that weight lol they could care less about the gvwr of truck as long as u up ur registration idk but its a toss up also I know you have to run dot numbers on any vehicle towing and I was told farm use or not they are gonna start cracking down.
post #6 of 6 Old 08-29-2013, 03:41 AM
RAINEY's Avatar
Did you have DOT Numbers and signage on the truck? Once you do that in most states you have to follow commercial vehicle guidelines. If you are clean of signage then you are typically exempt.
Every state is a little different on the regulations. Once you put the DOT numbers on then you follow Federal guidelines which supersedes the state rules.
I had to learn this in a big hurry when I was hauling hay especially over state lines
Jason
2012 F350 SRW Bought new with 550 miles on it in July 2013
RAINEY is offline
