IF IT WAS YOUR MONEY!!! - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 14 Old 08-25-2013, 05:26 PM Thread Starter
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Like my title states, if it was your $$$, which shocks, all 4 corner's, would you buy??? I know it will come down to either Rancho's or Bilsteins. Also, would you put the same part # on all 4 corners or would you put different one's in the front? All input is much appreciated.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #2 of 14 Old 08-25-2013, 05:32 PM
Don't you worry about it
strokinpower's Avatar
Quoted: 277 Post(s)
Im running the rancho MT7000 and they seem to be pretty good, but honestly on a stock truck the monroe reflex's are pretty dang good for the money. Pretty much everyone here will tell you Bilstein
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
post #3 of 14 Old 08-25-2013, 05:34 PM
broncojason's Avatar
Just put 5100 series Bilsteins on the front of mine last week, and absolutely love them. I'll be buying some for the rear soon.
2012 F250, Tuxedo Black, CCSB, 3.31, Banks Automind, leveled, Nitto Trail Grapplers.
broncojason is offline
post #4 of 14 Old 08-25-2013, 05:53 PM
Black2011SD's Avatar
I had Bilstein 5100 on my 2008 CTD, with Carli stuff, and liked them. I wanted to try something different this time, so went with Carli coils again, Carli /Bilstein HMS, Carli track bar, but did the King 2.5 pintops. Another option for you would be Fox or King.
Black2011SD is offline
post #5 of 14 Old 08-25-2013, 06:08 PM Thread Starter
Quoted: 4 Post(s)
Your not lifted right? Do you have the part #'s in case I decide to go this route?
Larry
14,000 LB GVWR,
Spray In Bed-Liner,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
post #6 of 14 Old 08-25-2013, 06:11 PM
Do you have any ambition for a lift /leveling kit?
post #7 of 14 Old 08-25-2013, 06:12 PM Thread Starter
Quoted: 4 Post(s)
Great question, None what so ever!!!
Larry
14,000 LB GVWR,
Spray In Bed-Liner,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
post #8 of 14 Old 08-25-2013, 06:16 PM
Bilstein 5100 or Fox makes a stock height replacement.
post #9 of 14 Old 08-25-2013, 06:34 PM Thread Starter
Quoted: 4 Post(s)
I have heard great things about the Bilsteins, not much exp. with Fox.
Larry
14,000 LB GVWR,
Spray In Bed-Liner,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
post #10 of 14 Old 08-25-2013, 06:38 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Im gonna stay with the Rancho's for the basic fact that we beat the pyzz out of them at work and very rarely do they fail. Might be a bit stiff but you know what its a truck....
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
