Removing the grille C's - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 21 Old 08-17-2013, 08:38 AM Thread Starter
IA Farmer's Avatar
I have searched but could not find much. I am wanting to remove the C's from my grille and was wondering if anyone has done a DIY write up on how to do so. Or if you know of any pointers that would be helpful I would appreciate it. Thanks
2013 F-350 CCSB Platinum
2010 F-250 CCSB Cabelas Edition - Sold
IA Farmer is offline
post #2 of 21 Old 08-17-2013, 01:11 PM
BIG Laing's Avatar
I haven't seen a write up, so I am subscribed.
Did see one thread with a guy that took them off, said "feels like you are going to brake something, but they do come off".
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #3 of 21 Old 08-17-2013, 03:19 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #4 of 21 Old 08-17-2013, 04:30 PM
BIG Laing's Avatar
Originally Posted by "Stroker 8" View Post
Your funny 8
post #5 of 21 Old 08-17-2013, 05:44 PM
RetiredFD's Avatar
Here you go...
http://www.powerstroke.org/forum/6-7...1-valence.html
- Chris
2006 F250 CCSB Lariat
RetiredFD is offline
post #6 of 21 Old 08-18-2013, 05:41 AM
Quoted: 4 Post(s)
Originally Posted by BIG Laing View Post
Your funny 8
You should see me after a couple of beers, I will bring the house down.
Larry
14,000 LB GVWR,
Spray In Bed-Liner,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
post #7 of 21 Old 08-18-2013, 07:11 AM
salnazzaro's Avatar
Quoted: 25 Post(s)
What are the odds I'm plasti-dipping mine as we speak!
2015 f350 cclb platinum...5% tint, Anzo smoked mirror lights, recon clear cabs, tgc 2.5" spacers, carli adjustable track bar, icon 5" rear blocks, Firestone riderites, B&W goosneck, line x, rancho 7000s, Fuel Mavericks wrapped in Toyo MT's, No Limit stage 2 cold air intake, 4" flo pro straight pipe, Sct w gearhead tunes, hideaway LEDs
salnazzaro is offline
post #8 of 21 Old 08-18-2013, 09:01 AM
02dura09's Avatar
i did mine, i took the grill off and you can see the tabs that hold it on, bend them so you can get it out and once you have it off you can bend the tabs back to their original place and it will snap in just fine ps i color matched mine
2013 CC/SB Lariat Kodiak Brown-22x12 Fuel Mavericks, 35x12.5 Toyo MT's, 4.5" Rough Country Lift, H&S Mini Maxx, Flo Pro dual 5", S&B Intake, 55W HID Headlights/Fogs
2008 Crew Cab Short Box-Sold
02dura09 is offline
post #9 of 21 Old 08-18-2013, 09:09 AM
Quoted: 4 Post(s)
Looks good!, What is involved with the Grille Removal???
Larry
14,000 LB GVWR,
Spray In Bed-Liner,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
post #10 of 21 Old 08-18-2013, 09:13 AM
salnazzaro's Avatar
Quoted: 25 Post(s)
5 bolts across the top and 5 push clips or whatever there called on the bottom, unbolt the top, lean it forward and get a long screw driver and press down on the 5 bottom clips to remove the grill
