Help with lift and Fuel Maverick wheels? - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 14 Old 07-18-2013, 05:29 PM Thread Starter
hirevn's Avatar
I will be installing either a 4.5 or 6 inch lift in the near future on my 2012 ( I want to run 37"s) and really like the 2 piece Fuel Mavericks with the chrome center. I have seen both 20" and 22" in either 10 and 12 inch widths being used on these trucks but i am unclear on what the offset should be, any suggestions? I am leaning towards a 6 inch kit with the 22x12 wheel but not sure how wide to go with depending wether i go 4.5 or a 6 inch kit (is a 10" a better width option?). I dont want them to stick out too far and look silly but will also likely want to add wheel flares to complete the look of a lifted truck with wider tires.
Also can anyone suggest a vendor for these wheels?
hirevn is offline
post #2 of 14 Old 07-18-2013, 05:43 PM
BIG Laing's Avatar
You need to keep less then 6" of backspacing. So for a 10" wide wheel between a +12 and 0 offset is perfect IMO. Some guys like them sticking out a little farther, and go with an offset between -12 and -24.
The smaller the offset (More negative) the further the wheels stick out.
Stock is +40 with an 8" wide wheel.
I would not suggest a 12" wide wheel.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #3 of 14 Old 07-18-2013, 06:11 PM Thread Starter
hirevn's Avatar
So looking at this http://www.mhtwheels.com/cms_pdf/D26...20Maverick.pdf shows me all the 22X12's have -44 and 4.75 bs so these would stick out a bit too much but would work. The 22x10's are -13 with 5.00 bs so these would be a better fit in the wheel wells?
hirevn is offline
post #4 of 14 Old 07-18-2013, 08:04 PM
BIG Laing's Avatar
IMO those are both pretty extreme offsets. The 22x10 with -13 will fit alot better then the 22x12.
Basically the inside of the rim face is in the same place for both wheels (1/4" different). But since the 12" wide are 2" wider, they will be sticking out 2" more.
post #5 of 14 Old 07-19-2013, 07:42 AM Thread Starter
hirevn's Avatar
Thanks for the help, maybe i will continue to search for a diffrent 22X10 wheel that has less offset than these Fuel Mavericks as they dont offer any choice in offset in either sizes.
hirevn is offline
post #6 of 14 Old 07-19-2013, 02:27 PM
If your going to run the 22x10 -13 offset you'll need a 6" lift for sure. I know you can custom order offsets in this wheel that are a +8 I do beleive, which is a 5.5 BS or something, you MIGHT be able to get away with a 4.5" lift with this setup.
'13 F250 CCSB Black/Black: Carli Starter & Stabilizer, Minimaxx, S&B intake, 5" FloPro, egr blocker, BMF Rehabs, Toyo AT IIs, Titan 50gl Tank, Amp steps, Blacked Out Tails/3rd/Markers, Full Custom Sound
highdrum is offline
post #7 of 14 Old 07-19-2013, 05:11 PM
BlueOx12's Avatar
That's not true. I run a 20x10 with a -25 offset and 37x13.50x20 Toyo MTs with just a 4in lift.
Help with lift and Fuel Maverick wheels?-imageuploadedbyautoguide1374282596.139559.jpg
Help with lift and Fuel Maverick wheels?-imageuploadedbyautoguide1374282629.768047.jpg
Sent from AutoGuide.com App
05 6.0 Extcab 4x4
Studded, Deleted, Tuned, and Sprayed.
BlueOx12 is offline
post #8 of 14 Old 07-19-2013, 05:40 PM Thread Starter
hirevn's Avatar
Truck looks sharp BlueOx!
Yhea i seen the other thread here with the 4.5" Rough Country and 22x12's so figured they would work. I will likley go 10's though as dont want them sticking out that much, plus i decided to go with a 6 inch lift.
hirevn is offline
post #9 of 14 Old 07-19-2013, 06:49 PM
BlueOX, how much trimming was in order to make that fit with out scrubbing on anything?
highdrum is offline
post #10 of 14 Old 07-28-2013, 07:36 PM
sandsportz's Avatar
Mines set at 7" with 20x12 and 38x15.50 toyos
08 Regency, Mini Maxx, dual 4" Flo Pro, S&B, 6" pro comp, 35s on 20s
sandsportz is offline
