people with leveling kits - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 36 Old 06-21-2013, 09:04 AM Thread Starter
Northernford's Avatar
when you have a heavy load in the bed or towing a heavy trailer, how does it work using airbags to level? or does it come to level? I have a 3500lb camper thats in the bed and then tow a 5500lb boat on a 36 inch extension. I want to put a leveling kit to get bigger tires but I don't know if it will look level even if I blow the bags all the way up.. Boats tongue weight is about 550lbs.
2011 F-350 FX4
Northernford is offline
post #2 of 36 Old 06-21-2013, 09:58 AM
HOUTX01X's Avatar
Quoted: 4 Post(s)
I just pulled my 31ft travel trailer. I aired the bags up to 30psi. It sat and pulled good. I didn't have to use my old distribution bars, just the sway bar. Pulls 20x better than the X. I also saw on the info screen it has some sort of electronic sway control built into truck.
Ether way it pulled straight no sway when's swinging by the big rigs.
I don't have an inboard air compressor so I use my shop one.
I hooked up trailer then aired it up to a point that looked good to me.
If I'm putting a heavy load in bed (flag stone, sod) ill air them up prior to picking up.
'11 F250 KR
XRT Pro, H&S SX-E turbo kit, NoLimit intake/intercooler
OUO bars/blocks
-EGR,CCV,1993pf
Leveled w/ 35 atII
HOUTX01X is offline
post #3 of 36 Old 06-21-2013, 11:00 PM Thread Starter
alright, but does the truck look level when you have all the weight on it?
2011 F-350 FX4
post #4 of 36 Old 06-22-2013, 02:04 AM
BIG Laing's Avatar
If you are that worried about it looking level with a load, this is what I would do.
Lift the front 2.5" and the rear 1". Or just lift the front 1-1.5".
What tires do you have now? If they are stock tires, all I want to know is your rim diameter.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #5 of 36 Old 06-22-2013, 07:11 AM
HOUTX01X's Avatar
Quoted: 4 Post(s)
Yes it looks level
'11 F250 KR
OUO bars/blocks
-EGR,CCV,1993pf
Leveled w/ 35 atII
HOUTX01X is offline
post #6 of 36 Old 06-22-2013, 09:37 AM Thread Starter
They are stock tires/rims. I believe 20 inch.
2011 F-350 FX4
post #7 of 36 Old 06-22-2013, 11:50 PM
lwg
I called and talked directly with Icon about this very thing. I told them that I'm a full-time RV'er and tow a lot. Wanted to get their leveling kit but still wanted a little rake. They told me to change out my 3+" rear blocks for some 5" rear blocks and I should be fine. Getting the leveling kits, 5" rear blocks and new wheels and tires put on next week so we'll see. Worse case ill add some airbags as well.
Sent from AutoGuide.com App
2013 F-350 6.7, Lariat, CC SB, 4x4, FX4, Tuxedo Black on Black, Transfer Flow 50 gallon, Method Racing 20" NV, 295/65/20 Toyo A/T II's
lwg is offline
post #8 of 36 Old 06-22-2013, 11:54 PM Thread Starter
When your all done would you post pictures up? I'd love to see how it looks with your truck.
2011 F-350 FX4
post #9 of 36 Old 06-23-2013, 10:18 AM
lwg
Definitely! I haven't seen any pics of this setup so I'm hoping it gives me the useful lift I want. The 4" lifts are just too impractical for me, I think they look great but the cons outweigh the pros for my particular situation.
lwg is offline
post #10 of 36 Old 06-23-2013, 10:20 AM Thread Starter
exactly, my profile picture is what I haul. GCW is about 18,000lbs roughlyl.
2011 F-350 FX4
