Chrome mirror covers - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 10 Old 06-09-2013, 03:11 PM Thread Starter
My truck came with the chrome caps on the side mirrors, I would like to take them off and paint them to match the body but I can't figure out how to get them off. Any suggestions?
bocalightning89 is offline
post #2 of 10 Old 06-09-2013, 04:19 PM
Lf83's Avatar
Quoted: 14 Post(s)
Tilt mirror all the way down. U should see 2 tabs behind. Get flat head screw driver and pinch tab to undo. U will see what I mean. Only 1 way to do it. Once both are undone pull cap up and away from mirror.
leveled 2011 F250
Fox 2.0 Shox
35x12.50x20 Toyo AT II's
20x9 Fuel Dunes
H&S MiniMaxx
5" MBRB 7"Tip
S&B CAI
Lf83 is offline
post #3 of 10 Old 06-09-2013, 07:00 PM
I highly recommend you buy the "paint to match" mirror caps and have those painted instead of over the chrome.
Painting over chrome will chip easily, and the paint doesn't stick well to it.
2012 F-350 supercab long bed srw lariat tuxedo black
MBRP 5" dp-back exhaust (thermal coated) with RBP 6" tip, AFE pro-dry s cold air intake, H&S mini maxx, H&S EGR delete, RBP rx3 nerf bars, RBP fender emblems, RBP rx2 grille with color matched grille surround, AMI color matched locking fuel lid
Soon to install..
RBP rear bumper, RBP front winch bumper w/ Warn 16.5ti, Icon 4.5" stage 3 suspension, Icon steering stabilizer/shocks, 35"x12.5" nitto trail grapplers, RBP Revolver 20" wheels
theinfamouskonrad is offline
post #4 of 10 Old 06-10-2013, 06:38 AM
Lf83's Avatar
Quoted: 14 Post(s)
Mine lasted 2 years. Sanded with 600 grit and put 3 coats on then clear. No chips or peeling at all. Buy good products and do it right and you'll get good results.
leveled 2011 F250
Fox 2.0 Shox
20x9 Fuel Dunes
H&S MiniMaxx
5" MBRB 7"Tip
S&B CAI
Lf83 is offline
post #5 of 10 Old 06-10-2013, 11:20 AM
Hellobatman's Avatar
How does the reflector/light assembly come out?
2013 F-250 Lariat FX4, 6.7 Scorpion, All the bells and whistles!
Hellobatman is offline
post #6 of 10 Old 06-10-2013, 12:10 PM
Lf83's Avatar
Quoted: 14 Post(s)
Yes. Push mirror in towards door and up. White tab behind mirror.. push with pen or flat head. Lense pops off.
leveled 2011 F250
Fox 2.0 Shox
20x9 Fuel Dunes
H&S MiniMaxx
5" MBRB 7"Tip
S&B CAI
Lf83 is offline
post #7 of 10 Old 06-10-2013, 06:49 PM
Thanks!
post #8 of 10 Old 06-12-2013, 07:16 PM
Quoted: 18 Post(s)
I think it would be better to apply adhesion promoter instead of scuffing/sanding the chrome so you can have a durable, smooth paint.
truckfan is offline
post #9 of 10 Old 06-13-2013, 12:10 PM
Lf83's Avatar
Quoted: 14 Post(s)
If u just spray primer on the chrome plating it will run and spot up. 600-800 is for wet sanding. When done properly I had to tilt my mirror cover to see the marks. Then after a few coats of paint and a few of clear gloss you can't see any scuffs.
leveled 2011 F250
Fox 2.0 Shox
20x9 Fuel Dunes
H&S MiniMaxx
5" MBRB 7"Tip
S&B CAI
Lf83 is offline
post #10 of 10 Old 06-22-2013, 08:12 PM
I plastidiped my grill and mirror caps and believe it or not it holds up real well.
The.Most.Truth is offline
