Carli add a packs, do they center the rear axle? - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 2 Old 03-16-2013, 07:47 AM Thread Starter
Bad Superduty's Avatar
Have their 4.5" kit ordered and wondered if the progressive add a pack will center the rear axle in the wheel well like some kits do?
Thanks
2012 F-350 King Ranch
Bad Superduty is offline
post #2 of 2 Old 03-16-2013, 11:41 AM
Skyd Ram's Avatar
Quoted: 149 Post(s)
Thanks
No,
Since the add-a-packs use the factory main leafs the centerpin location cannot be changed. Their full replacement Deaver leafs are designed with the center pin further forward in the pack to help with clearance. Also companies Like Pure Performance have rear block/u-bolt plate combinations that allow you to position the axle in multiple locations for the same reason.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
888-886-2480
Skyd Ram is offline
