Carli Suspenion Suggestions 4.5'' - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 7 Old 02-23-2013, 01:02 PM Thread Starter
Well I've finally gotten the green light from my wife to get a suspension on my 2012 KR. I planned on going with the 4.5'' 2.5 King Coilover. Because I most likely won't get the green light again. I'd like to buy everything I "need" at once and not have to deal with going back to her and saying I need this this and that.
Would you guys say the 2.5 King Coilover system covers everything? Or are there additional things I should purchase to my truck and suspension rotemck.
And finally you guys have any suggested vendors to buy this system from?
bricewise is offline
post #2 of 7 Old 02-23-2013, 03:03 PM
BIG Laing's Avatar
I think the CO isn't the way to go, that's just my opinion. Pintop is where it's at. If you have a green light, no limit. Make sure you get OUO ALA's too!
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #3 of 7 Old 02-23-2013, 03:27 PM
BgCountry's Avatar
The OUO ALA's are the way to go. For sure.
2012 F350 Lariat PS CC FX4 Tuxedo Black, Tinted, 20's, Recon Side Lens, 3rd Brake Light, De-Stickered, Epic Door Seal Mod, Reflex Liner, Spyder Headlights W/RFS 5K HID's, B&W Turn Over Ball W/Andersen Ultimate Fifth Wheel Connection.
2011 Keystone Laredo 310 RE
BgCountry is offline
post #4 of 7 Old 02-23-2013, 04:27 PM Thread Starter
Big Laing. What makes you like pintop over coilover?
post #5 of 7 Old 02-23-2013, 05:51 PM
6.0L Stroker's Avatar
The coilover won't ride any better than the pintop kit. It's basically just a different location for the one shock so that people can add bypass shocks for better off road performance.
Sent from AutoGuide.com App
2011 F350 CC/SB Bronze and Gold KR tinted windows, spray in bedliner. MBRP 5in filter back with 6in tip and Mini Max. S&B Dry Intake, TGC Dual Stabalizer.
Sold 2004 Ford F-350, cc/lb Lariat, Procomp 6.5 lift with 37/13.5/17 Toyo Mts, Id tuned Ficm, Bully Dog Triple Dog, MBRP all the way back,
6.0L Stroker is offline
post #6 of 7 Old 02-23-2013, 11:28 PM
BIG Laing's Avatar
$1000 more for kit that rides the same on pavement. And CO is not bolt on, you have to grind off the centering nub. Which means (I believe) you can't go back to stock. Anyone know for sure?
post #7 of 7 Old 02-24-2013, 04:47 AM Thread Starter
If its not bolt on thats pretty much a deal breaker. I didnt realize Coil-over wasn't bolt on.
