2012 Cab Lghts - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 10 Old 01-12-2013, 02:42 PM Thread Starter
Traveling Man's Avatar
2012 Cab Lghts
I just spent this afternoon installing cab lights on my new truck. They look great but it was a PITA to install them. I bought the Ford factory lights and harness, that was the easy part. Taking down the headliner and associated trim was very difficult. I am very picky about how things go back so it spent more time than the average person would have. I can say one thing about the install, it is easier to lay the light holes out from the inside of the cab then it is to do it from the top. I don't have a sun roof. It would have been a litter easier if we had a work platform to access the roof line. Working off the running boards were terrible. Also I drilled the holes the same size as I needed and ended up drilling a larger hole. My advise is drill a 1/8" larger hole than you need and the light will drop in fine. I used a little silicone around the opening for insurance. We also draped a sheet inside the cab to catch all the shavings, this would be more difficult it you dill everything from inside the cab. All in all I pleased with everything and I'm glad I did it.
Traveling Man is offline
post #2 of 10 Old 01-12-2013, 03:23 PM
2000-7.3L's Avatar
Feedback Score: 10 reviews
Pics?
Sent from my iPhone using AutoGuide.com Free App
2000-7.3L is offline
post #3 of 10 Old 01-13-2013, 05:48 AM Thread Starter
post #4 of 10 Old 01-13-2013, 05:53 AM Thread Starter
Originally Posted by Traveling Man View Post
I knew when I posted that it was worthless without photos!
post #5 of 10 Old 06-10-2015, 07:13 PM
Stroking Smoke's Avatar
Quoted: 2 Post(s)
How much was the harness and lights? Have you had any issues with leaking? I want to do mine but am worried it might be to tough of a job
Smoke
2012 F-250 6.7L CC SB FX4 Lariat
Recon Side Marker lights smoked, Blue water LED's in bed, Delete Pipe, EGR Block Off Plates, SCT LWTS w/ PIP tunes all from No Limit Fab
2006 F-250 6.0L CC SB FX4 Lariat Completely deleted and strong (My Wife's daily driver)
Stroking Smoke is offline
post #6 of 10 Old 06-11-2015, 05:41 AM Thread Starter
No problem at all with leaks. I applied some silicone around the holes before I bolted them down. You can get the lights and harness from the dealer for around $150. I have seen them on EBay for about the same amount. Keep in mind the wiring harness is vehicle specific so make sure they get you the right one.
post #7 of 10 Old 06-11-2015, 04:44 PM
Quoted: 2 Post(s)
How long did it take you to do the install. What was the hardest part of it
Smoke
post #8 of 10 Old 06-12-2015, 03:37 AM Thread Starter
It took about 4 or 5 hours to layout the holes and drill them to accept the fixture.
The hardest part in my opinion was removing all the trim, visors, and headliner. That stuff is just frustrating to remove without damage.
The old saying "measure twice" cannot be overstated. I masked the roof area off with painters tape and really spend a great deal of time measuring and laying out the work. Taking your time doing this will insure your success.
post #9 of 10 Old 06-16-2015, 06:49 PM
Quoted: 2 Post(s)
Where does the harness plug in? Passenger side or driver side
Smoke
post #10 of 10 Old 06-17-2015, 03:52 AM Thread Starter
It routes down the drivers side pillar and connects under left drivers foot well. You will replace the existing harness with the new one for the cab lights.
