Help with reverse lights! - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 2 Old 12-12-2012, 03:06 PM Thread Starter
tekemp's Avatar
I need some opinions i have some LED lights im going to use for reverse lights and i was originally going to wire them just to the upfitter switch and turn them on and off manually. My question is if i wire them like that and then tap a wire to the signal wire going to the relay from the factory reverse lights would i need to install two diodes, one on each side to prevent backfeeding. That way they would come on with the factory reverse lights and by the switch if i wanted.
Thanks, Tommy
2012 F-350 CCLB XLT/EGR/WEATHERTECH/RIGID/CTS/
tekemp is offline
post #2 of 2 Old 01-01-2013, 09:25 AM
Good question I want to do the same thing.
sxr_nathan is offline
