Projector Back Up Lights - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 8 Old 10-04-2012, 04:01 PM Thread Starter
Quoted: 3 Post(s)
I'm looking to install these on one of the upfitters. I was looking for some advice on brand and also installation. I'm hoping I don't need to do any hole drilling. I've been looking at the Recon Brand, I just can't see how you would mount them. Thanks in advance.
rrogersgsp is offline
post #2 of 8 Old 10-04-2012, 04:12 PM
kirbybc12's Avatar
SIRENNET.COM - SoundOff GHOST LED Mini Light
Literally just posted these on another thread haha. They drill into rear bumper and wire to your upfitters and your reverse gear. Here's a pic of them mounted in my old bumper.
2012 F-350 Lariat FX4 CCSB
2.5" Carli Commuter
Carli High Mount Steering Stabilizer
AFE Cold Air Intake
Truxedo Lo Pro QT
Line-X
Dura-Flap Mud Flaps
Timbren SES
High Idle
35x12.5x20 Toyo AT II Extreme
H&S Mini Maxx, 4" AFE Turbo Back
kirbybc12 is offline
post #3 of 8 Old 10-04-2012, 04:56 PM
Alberta Advantage's Avatar
Quoted: 20 Post(s)
This is my truck. The two lightbars on the sides are controlled by an upfitter. The two near the hitch and the one above the tailgate are triggered by the reverse signal. They are all Vision X lights. The ones near the hitch are 10 watt Solstice Solo, the tailgate is a 12" XMitter Prime low profile, and the two on the outside are 8" Evo Prime single stacks.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #4 of 8 Old 10-04-2012, 07:33 PM
KAKnight's Avatar
This is my 06 f150. If you go the rout of getting a headache rack and rear replacement, I suggest getting the maxxima hybrid light. Bright as chit. I'm going to do the same to my 6.7 as soon as I can build a headache rack for it.
- Bubba
KAKnight is offline
post #5 of 8 Old 10-06-2012, 04:27 AM
I went with the recon light. Claims to be submersible, but they both have condensation on the inside. Sent one back for replacement, and the same thing happened. They still work fine, but you can see moisture in there.
2012 6.7L King Ranch Bronze Metallic
Traded up from 2003 Avalanche 5.3L
CW2 US Army
Currently: Watercraft Engineer
Previously: Prime Power, Recruiter, Infantry
Prime Power is offline
post #6 of 8 Old 10-06-2012, 06:27 AM
Term3's Avatar
Quoted: 2 Post(s)
I'm thinking of buying Hella's pot string daytime driving lights for my rear bumper. They're one inch around and come in four, six and eight light strings. That way everything is flush and nothing is hang down.
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #7 of 8 Old 10-06-2012, 07:54 AM
You can't go wrong with some rigid D2's
2003 7.3 CCSB
PHP Chip, Full Force Stage 2's, 38R, Tymar, ISSPRO EV2 Boost/Pyro/Tranny, Diamond Eye Duals 4"
Skew12 is offline
post #8 of 8 Old 10-06-2012, 09:01 PM Thread Starter
Quoted: 3 Post(s)
Thanks for the input. I'll check them all out.
