Use of courtesy time out - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 3 Old 09-22-2012, 09:31 PM Thread Starter
Adventure Rider's Avatar
Planning to get a set of dual white and amber LED's to mount on the step rails
I got the Ambers figured out to be running and turn signals.
What I am struggling and looking for some help is that I want to have the white LED's come on just until I get to the vehicle and then shut off
Thinking of using the courtesy timer circuit for that but have no clue where/how to access
The other option is using a control signal that I would tap off when the vehicle is removed from park
Help in either of those plans or suggestions for another method are greatly appreciated
2012 F250 6.7 PSD XLT CCSB FX4 3.55 ELD Tuxedo Black Line-X, Weather Tech Floor Mats, Ford Molded Mud Flaps and Wheel Liners
Adventure Rider is offline
post #2 of 3 Old 09-23-2012, 02:38 PM
Geodude's Avatar
Not sure about the XLTs but on the Lariats there are unused connectors for running board lights you can tap into. Up under the truck, maybe two-thirds the way back the length of the running boards.
I installed while LED lights above the running boards, and they come on with the courtesy lights, and fade out with them as well. Here's a vid:
https://picasaweb.google.com/1067113...15398252416306
2011 F-350 6.7L Lariat Crew cab, short box, platinum white with adobe
2012 Heartland Greystone 33CK triple-slide 38' 5er
Geodude is offline
post #3 of 3 Old 09-23-2012, 04:03 PM Thread Starter
Thx!
I will check
Nice video - exactly what i want to do
