2012 F-250- best leveling kit - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 15 Old 09-17-2012, 09:47 AM Thread Starter
Quoted: 9 Post(s)
I just bought a 2012 F-250 lariat fx4 6.7. I am looking to level the truck but run stock rims. I am wanting to hear some opinions on what is the best leveling kit (quality and ride) and what is the best tire to run on factory rim? thanks for the help.
Ford#2oil is offline
post #2 of 15 Old 09-17-2012, 05:27 PM Thread Starter
Quoted: 9 Post(s)
I have heard some talk about Icon and Carli lifts. What are the thoughts on these lifts as far as quality and ride? What would my best option for a leveling kit be if I want to stay leveled when pulling a load (5k or less)? I want really wanna run anything bigger than 35s but I wanna feel the fender wells good. Any feedback would be appreciated.
post #3 of 15 Old 09-17-2012, 06:10 PM
Skyd Ram's Avatar
Quoted: 149 Post(s)
Here is some info about the upcoming Carli 2.5" kits:
Carli Leveling Kit Sneak Peak!
Hopefully they will have solid pricing details available in the next few weeks.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
888-886-2480
Skyd Ram is offline
post #4 of 15 Old 09-18-2012, 07:15 AM
OCVeloMan's Avatar
Quoted: 179 Post(s)
Garage
Just posted my pictures in that thread as well! I can tell you the only truck that rides better than mine (that I've been in) is the 2008 pictured in the thread above. The longer springs make the rear quite plush.
OCVeloMan is offline
post #5 of 15 Old 09-18-2012, 12:41 PM
vlxjim's Avatar
I run the Icon stage 2 lift with track bar and duel stabilizers on mine. Its ride great and you get 50% more wheel travel out of it. Vs a spacer type lift. I like the ride better than stock. I can't say about the Carli lift but the 2012's come with longer and wider rear springs. And its hard to see how adding more springs to the F250's spring pack would make it more plush. Just saying. 35-12.5 would run good with stock wheels. And if your not offloading much I would look at Icon Stage 1 with a track bar or Icon spring kit with Bilstines shocks and track bar.
2011 F250 PowerStroke CCSB Lariat FX4 Loaded | Icon 2.5" Stage 2 | Icon track bar | Top Gun Dual Stabilizers | 20" Fuel Boost wheels +1 offset | 325-60-20 Hankook Dynapro ATm | RBP RX3 steps | BakFlip F1 Bed Cover | All Sales Mfg Fuel Door | Randy Ellis Light Bar | Hella Lights | aFe Magnum FLOW Pro-GUARD 7 Air Filter |
vlxjim is offline
post #6 of 15 Old 09-18-2012, 12:59 PM
OCVeloMan's Avatar
Quoted: 179 Post(s)
Garage
Because we remove the lower overload and the upper helper and replace them with a progressive multi-spring add-a-pack for progressive spring engagement. More comfortable in all situations and maintains factory load capacity.
post #7 of 15 Old 09-18-2012, 01:45 PM
vlxjim's Avatar
See here is were it gets weird. We had at one time a large tread on the rear springs on the 2011-12 F250 - F350's. Some of us went back to the dealer and looked at all the trucks on the lot. What we found is that most all F350's had 3 to 4 +1 helper springs. On the F250's some (few) had 4 +1 helper. Some had 3 +1 helper with camper package. But most had (like mine) only 3 springs. So with that you would take off my bottom short spring and add 5 in its place. You can see were one can get confused. Ford had stated that going to the new longer wider 2 with 1 over load was to improve the ride.
F350 with Carli spring pack
Here is the F250 stock springs
vlxjim is offline
post #8 of 15 Old 09-19-2012, 01:29 PM
OCVeloMan's Avatar
Quoted: 179 Post(s)
Garage
We gurantee that you can carry the same payload that your truck could carry stock; therefore, we ONLY REMOVE the overload (Thick leaf on the bottom that doesn't follow the contour of the pack) and the helper (thin separated leaf on the top that hits the pads extending from the frame under load.) The main pack remains and we essentially add a progressive version of the overload to ensure you can still haul and the leaf pack is still supported but the edge is taken off your ride.
post #9 of 15 Old 09-19-2012, 02:08 PM Thread Starter
Quoted: 9 Post(s)
how does this icon lift ride compared to stock? i have never leveled a truck where they didnt guarentee that it will not affect the facotry ride and everytime the trucks suspension ended up being a lot stiffer and in my opinion it rode worse. is there any way to level the truck and not have the drake in the back when under a light load?
The Following User Says Thank You to Ford#2oil For This Useful Post:
DeanRyan (12-29-2013)
post #10 of 15 Old 09-19-2012, 02:28 PM
OCVeloMan's Avatar
Quoted: 179 Post(s)
Garage
The ICON rides better than stock but they don't adress the rear springs so it still hops. I just had a customer come in after 20 days with his ICON system and he switched to our pintop after adding our full spring pack to his ICON suspension because they didn't address the rear on his $6000 suspension system. Not bashing, take it for what it's worth...
