Help! Need to fill holes on my roof... - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 15 Old 07-24-2012, 06:45 PM Thread Starter
scummins's Avatar
THe moron who had my truck before me put a luggage rack on the roof. Looked horrible, so I took it off. Now there are 12 screw holes in my roof. For now I put the screws back in with silicone, but the sheetmetal is pulled up at teh screws and it looks horrible. There are 3 screw at each mount location. The area I need to cover is about 3 to 4 inches long at each point to cover the screw holes. WHat is something I could put back over these like cab lighting or something? SHould I just put the stupid rack back on?
I can't Believe someone would just screw into the roof of a 60k truck...this is bothering the **** out of me. Please help!
11 Lariat
6" lift, 37's, Moto Metals, H&S, SPE, JL SPL2K
scummins is offline
post #2 of 15 Old 07-24-2012, 08:21 PM
take it to a shop and live with the fact that ur truck will have bondo on it the rest of its life or pay major bucks and have them cut and weld in new metal
kk_kalina is offline
post #3 of 15 Old 07-24-2012, 09:36 PM
#1, it was his truck and he/she did what they wanted and loved the rack, and somehow you're the dummy for buying the truck to begin with.
#2, go to any auto parts store, they all have small black plug holes. i use the all the time in the firewall of my racecars, you might have ti add a silicone bead since your application is on the exterior.
#3, take it to a body shop and be prepared to for over several grand in body work. hope you got a killer deal when you bought it, enough to swallow paying for body work.
mchottie is offline
post #4 of 15 Old 07-24-2012, 09:38 PM
mchottie is offline
post #5 of 15 Old 07-25-2012, 04:41 AM
ceking35's Avatar
Quoted: 5 Post(s)
He's on here asking for help, and you're calling him dumb for buying the truck? That's what this forum is for, help, not for bashing eachother.
As for the truck, I agree, take it to a shop with a good reputation and see what they say. Maybe cheaper than you think.
ceking35 is offline
post #6 of 15 Old 07-25-2012, 05:21 AM
BIGGDADDYT's Avatar
Yea I would bite the bullet take it to a body shop and see how much they want to fix the holes.....You could temp it with some of the above solutions but if you are like me it will bother you till you just pull the trigger and get it done....It might hurt the wallet for a bit but knowing you got the truck to you liking and will be happy with it long term makes it all so much better to drive.
2012 F-350
Dually
FX4
Black on Black
Line-X Bedliner
BIGGDADDYT is offline
post #7 of 15 Old 07-25-2012, 12:43 PM
Quoted: 5 Post(s)
Any pics of the rack installed. It sounds really cool.
Ha, not really but a pic woud be awesome.
svtbolt2001 is offline
post #8 of 15 Old 07-25-2012, 04:27 PM
it's like buying a used trailer without fenders, and then coming on a trailer forum to complain & ask where to buy fenders.
#1, you should have bought a trailer WITH the fenders, or #2 you should live with it without the fenders.
OP above decide to remove the rack, I guess maybe he thought there wouldnt be mounting holes?
i'm not bashing, i'm just wishing people had more common sense!
and yes, take it to a professional to at least get a price quote, altho my gut feeling says its going to be A LOT more than you are expecting.
mchottie is offline
post #9 of 15 Old 07-25-2012, 08:13 PM
Alberta Advantage's Avatar
Quoted: 20 Post(s)
I had holes in my bed from a transfer tank that I took out because I didn't use it and it took up room in the bed so I had a local shop weld in bolts, grind them down flush with the bed, and then got my bed Line-X'ed. No problems whatsoever. Looks like new. Don't have a solution for your roof as people see that so it the holes will have to be repaired, dents pulled out, and the roof repainted. Sounds like an expensive trip to the body shop. I can only imagine what that would cost. I was quoted $2100+ to put in aftermarket cab lights from a body shop when they're a $75 option from the factory. Good luck at the body shop!
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #10 of 15 Old 07-26-2012, 04:59 PM Thread Starter
scummins's Avatar
Since you are so smart mchootie, you would know that there are more professional ways to mount to sheetmetal, such as blind nuts, retainers, what ever, anything but driving steel screws right into the roof of a 60k truck so far and hard that it distorts the metal around it, then rusting. Luckily I had enough "common sense" as you put it, to remove it and find this issue before it became a real problem. I was expecting to find a nicely drilled hole, with some type of nut and some sealant under there, however when I purchased the truck it had the plastic trim piece covering the mounting screws and I couldn't see what a derelect installation it truly was.
I'll post a before and after pic soon. Thanks for your input
11 Lariat
scummins is offline
