Tire Choices??? Stock f-250 - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 3 Old 07-06-2012, 02:26 PM Thread Starter
Just picked up a great set of XD 22x9.5 wheels for my truck. I'm going to keep my truck stock height, so I wanted to get a wheel that is proportionate to the truck and wheel well. (Not much offest with these wheels)
From what I've read on the forum, you can stuff a 37 tire underneath a stock height truck, but you will rub significantly and you have little to no travel. I want to put a tire on that will fill the well nicely, but not sacrifice the steering capability or vertical suspension travel.
I was thinking a 33-34? Or can a 35 fit without sacrifice? I like the Nitto Terra's for a mild traction update and look. I don't need Toyo MT's. Are there any alternatives to the Terra's that I should consider?
As always, thanks for the great input and I appreciate any and all feedback.
jettob is offline
post #2 of 3 Old 07-06-2012, 05:20 PM
A 325/50R22 Terra Grappler should be just perfect. Please don't ruin a beautiful ford with BFG All Terrains
Current Rig: 2011 F-350 CCSB Lariat chrome FX4 Tuxedo Black.
Mods: aFe stage II, 8000k HID. 6" 4link Skyjacker Lift, 37" Toyos Wrapped around 20x9 XD MisFit Rims, H&S Minimaxx, 5" FloPro straight pipe
Traded: 2006 F-350 CCSB Amarillo Edition
Mods: 6" BDS 4-Link Lift Kit, 4" MBRP Cool Duals Exhaust, AFE Intake, Edge CTS Evo, 37x13.5x20 Toyo MT wrapped around XD Spy 20x9 Rims
UA Local 488 Steamfitter/Pipefitter
AlbertaStroker is offline
post #3 of 3 Old 07-06-2012, 06:29 PM
285/55/22 34.3" tall - Almost the same as factory. Look great and won't mess up your speedo too bad. I wouldn't run a 325 on a 9.5" wheel with a positive offset. To run a tire that wide you need the wheels to stick out or the tires are going to rub.
Ratings, reviews and specifications for Nitto Trail Grappler M/T tires
Andrew010 is offline
