LED Reverse License Plate Light - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 8 Old 07-03-2012, 12:09 PM Thread Starter
joec410's Avatar
Quoted: 3 Post(s)
Has anyone installed one of these on their Superduty? I think this would make a great reverse light. I am very interested in buying one of these, but I am not sure if there is enough room for the light in between the license plate and the bottom of the tailgate, also I do not want the tailgate to hit the light when you open the tailgate.
XIL-LICENSEPLP910 Vision X License Plate Bracket and 12" Xmitter Low Profile Prime 40 Combo
2012 Ford F-250 Lariat, CC, LB, 4x4, 6.7 Powerstroke, 3.55 E-locker, Nav, Chrome BMF Novakanes 20"x9", 305/55-20 BFG AT's
joec410 is offline
post #2 of 8 Old 07-03-2012, 12:23 PM
SuperCrutyPS's Avatar
Quoted: 321 Post(s)
Garage
Looks pretty cool. You might want to contact them to get the dimensions of it so you can compare them with your license plate and the space above it before you buy it.
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is online now
post #3 of 8 Old 07-03-2012, 03:49 PM
Alberta Advantage's Avatar
Quoted: 20 Post(s)
I have a couple Vision X lights. I like them.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #4 of 8 Old 07-03-2012, 07:50 PM Thread Starter
joec410's Avatar
Quoted: 3 Post(s)
Alberta,
Can you send me some more pictures of the 12" Xmitter Low Pro? How did you mount yours? Did you have any issues with tailgate clearance? Thank you for the information.
Thanks,
Joe
joec410 is offline
post #5 of 8 Old 07-03-2012, 08:14 PM
Quoted: 20 Post(s)
It is kind of a tight fit to get the XMitter Low Pro in there. Hence the reason why it is mounted kind of low. The frame of the light on the bottom is flush with the top of the bumper and I angled it down slightly so that it would shine on the ground in the path of my backup camera. This gave me plenty of clearance without notching the bumper to open and close the tailgate and remove the tailgate without having to remove the light or having to fumble around with the tailgate when removing it. I wired it up along with the two Solstice Solo lights to my reverse lights. The other lightbars, the 8" Evo Prime bars, are wired to an aux switch. I wouldn't go any larger than a 12" model though because of the spare tire wind down thing. I'll get some more pictures for you tomorrow. Don't have any good closeups of the lightbar. As for mounting it, I fabbed up a bracket. I'll grab some pictures of that too. Basically, the brackets look like a "Z". Hard to explain what I did but hopefully, pictures will help you out.
Putco Window Visors
Line-X
Bak Flip F1
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
4" Solstice Prime
Truck Bed Lights
post #6 of 8 Old 07-05-2012, 03:03 PM Thread Starter
joec410's Avatar
Quoted: 3 Post(s)
Alberta,
Yes, if you could send me some additional pictures that would be great. I have an idea of what you did with the Z-Brackets but I would just like to make sure. I sent you a PM with my email address.
Thanks,
Joe
joec410 is offline
post #7 of 8 Old 07-06-2012, 05:51 PM
bltp203's Avatar
How about a picture of what is looks like behind the truck with all those on......must turn night into day.
2012 F-350 CCSB 4X4, plow package, Skyjacker 1" leveling kit, 295/70/18 Nitto's
bltp203 is offline
post #8 of 8 Old 07-06-2012, 07:39 PM
Quoted: 20 Post(s)
Originally Posted by joec410 View Post
Alberta,
Thanks,
Joe
Still working on trying to grab those pictures for you. Rained again today. The XMitter Prime Low Pro will definitely fit though. I got mine in the widest pattern which helps to illuminate the area behind the backup camera. The 2" Solstice Solo lights are in a spot configuration so I can see what's behind me. The girlfriend's ranch has long and narrow stalls for trailer parking so it helps a lot with the spots at night.
Front end night shot
Both of the 8" lightbars on. Don't have any with just the XMitter Prime and the Solstice Solo though but they are bright.
Putco Window Visors
Line-X
Bak Flip F1
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
4" Solstice Prime
Truck Bed Lights
