What tires and lift for highway - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 8 Old 06-23-2012, 07:22 PM Thread Starter
2012 F250 CC SWB King Ranch. Looking for the "perfect" set up for a toy and hunting/Fishing truck not a daily driver, but will be driven significantly on highway. Must handle at least as good as stock, can't be any louder. I am thinking Carli back country 4.5" and Toyo MTs. Local shop pushes Toyos, big time. Second option is Icon 2.5" and Nitto Terra Grappler, I really would prefer to keep the factor KR wheels as long as they can handle the wider tire. also is the Icon dual stabilizer and panhard bar a must, looks to be? My mechanical skills are average, am I crazy to do this myself vs. paying a shop to do the work? I like to tinker. Thanks in advance for the input and ideas, fire away!
C130herc is offline
post #2 of 8 Old 06-23-2012, 07:28 PM
jmast's Avatar
you bought a $60,000 toy?
lol but really welcome and yes that set up would look sweet but those will be louder then stock, not to bad compared to others though
2004 F-250 crew cab short bed, rattle can red!
-arp headstuds
-sinister egr delete
-new oil cooler
-sct custom tunes
-edge cts with egt probe
-8 inch lift with dual resevoirs up front
-dual steering stabilizers
-38 inch mud terrains
-on board air system
-5% tint all around
-4inch exhuast turbo back with 6 inch tip
to come:
-2 way alarm
-lots of LED's!!!
jmast is offline
post #3 of 8 Old 06-23-2012, 07:29 PM
Don't you worry about it
strokinpower's Avatar
Quoted: 275 Post(s)
I put the lift on my '08 and would definitely pay someone to do it if I had to do it again.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
post #4 of 8 Old 06-23-2012, 08:19 PM
4.5" lift with 35" tires is about perfect.
I don't tow/haul anything, more of a play toy for me. My truck is only driven on the pavement, interstate and around town. Drives better than stock but definitely isn't as quiet. 35" MTs are going to make some noise going down the interstate.
The factory wheels are not going to look very good with a 4.5" lift and mud tires. Need wider wheels that stick out some to look right IMO.
I installed my lift, by myself in a afternoon. With some basic hand tools (air tools help), jack stands and a good floor jack you shouldn't have any problems. As long as you're comfortable doing a project like this and have all the necessary tools to get it done. Front track bar is the worst part, IMO. 3/4" sockets and breaker bar are almost a must have and it needs torqued to 406 ft lbs on reassembly.
Good luck and post pics when you're done.
Andrew010 is offline
post #5 of 8 Old 06-23-2012, 08:41 PM
carli pintop 2.5 and nitto trailgrapplers is how im going talked to dan at carli he said the pintop is the best option really
kk_kalina is offline
post #6 of 8 Old 06-23-2012, 08:55 PM Thread Starter
Point taken on the tires. Which are going to have less road noise and ride the best toyo MTs or Nitto Terra Grapplers? I assume the Nittos give they are an AT tire?
C130herc is offline
post #7 of 8 Old 06-24-2012, 08:03 AM
Not fair to compare the toyo open country M/T to the nitto terra grappler. Nitto trail grappler would be the fair comparison.
Trail grappler will be a bit quieter than the toyo, from what I've heard.
Terra grapplers will be much quieter, but have far less traction and not look nearly as good.
post #8 of 8 Old 06-24-2012, 03:55 PM
2006F350's Avatar
I love my Toyos,they are quiet for the aggressive tread and wear very well.
I also use my truck for mainly hunting and fishing, most of my miles are traveling to different states to hunt or pulling boats around in my state.
For that reason I went with no lift, fewer problems down the road and the cash I save in fuel over the next 5 years or so will more than make up for any price increases and pay for some of the add-on's I will want for it.
Rich
KC Stage 3, FF 190/75, UCF Ported O-Ringed Heads, Warren Comp Plus Transmission, ARP, Sinister Up & Charge Pipes, ODAWG Ported Intake, Atlas 40, IPR EGR Delete, DD RR Kit , Fass 200, BD Exhaust, Mishimoto CAC & Radiator, BPD Water Pump, OUO Bars, MBRP 4 TB SS Duals, Sinister Coolant/Oil Bypass Edge CTS w/EGT & FP, SCT X4, DC Power 190 AMP, Hellwig Sway, No Limit Cold Air, Beans Sump, Gearhead Tunes
2006F350 is offline
