Mud Flaps - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 10 Old 05-01-2012, 03:21 PM Thread Starter
ucpa111's Avatar
Quoted: 7 Post(s)
Mud Flaps
Ok...I've done some searching on here but not found what I am looking for.
I have an F350 with the 20" wheels and tires. I am looking for pics of same setup with mud flaps. I am not sure what brand I like. It doesn't seem like there's a lot of room between the rear tire and the wheel well at the rear of the truck.
Looking at Ford, Weathertech, Duraflap. I see pros and cons to each. Like the duraflap flexibility and length - price is high and worried about them flapping into exhaust or rubbing tire.
Any help is appreciated.
And...anyone put wheel well liners in the rear wells? If so....looking for what brand and pics and what you like about them. I don't like that everything is so open right now...
Thanks in advance!
2012 F350 CCLB 3.55 ELD with 20s. Lariat package, Chrome, FX4, Clearance Lights, Rapid Heat, Two Tone, Upfitters, HD Alternator, 5th Wheel prep, Truxedo Lo Pro Tonneau. Linex. On board air and shocker XL train horns.
THIS THING ROCKS!
ucpa111 is offline
post #2 of 10 Old 05-01-2012, 03:49 PM
Alberta Advantage's Avatar
Quoted: 20 Post(s)
I have an '09 F350 and had the OEM Ford mudlaps and they weren't long enough. They were too short and didn't provide adequate coverage. I now have Dura Flaps with the stainless steel weight and am happy with them. So far, they've lasted through a few Canadian winters with all the snow, slush, and water from winter, as well as some mud. There are no rips or tears in my mud flaps. They've also stayed the same shape more or less and haven't curled. The Dura Flaps are not very flexible. In fact, they are made out of what I'd say is a hard but durable plastic. Hence the reason they don't curl and won't rip.
These are the OEM Ford flaps
Dura Flaps
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #3 of 10 Old 05-01-2012, 04:02 PM
Rob
Rob's Avatar
Quoted: 2 Post(s)
pm sent......
Audentes Fortuna Juvat
(Fortune Favors The Bold)
The Org. Staff reserves the right to
move, modify, delete or merge threads/posts
at our discretion, without explanation
at any time.
Rob is offline
post #4 of 10 Old 05-01-2012, 04:03 PM
Rob
Rob's Avatar
Quoted: 2 Post(s)
Duraflap changed the material they use and it is very durable. they guarantee their product.
at any time.
Rob is offline
post #5 of 10 Old 05-01-2012, 05:19 PM Thread Starter
ucpa111's Avatar
Quoted: 7 Post(s)
Alberta - what length duraflaps are those? They have 9", 11" and 14" I believe...
Thanks for the pics and info! Much appreciated.
THIS THING ROCKS!
ucpa111 is offline
post #6 of 10 Old 05-01-2012, 06:25 PM
Quoted: 20 Post(s)
The front and rear mudflaps are both 12" wide since I'm running OE spec tires. My front flaps hang 9" below the fenderwell (STYLE# FF 2 08 SS). My rears are the ones that hang 16" below the fenderwell (STYLE# FR 2XL 08 SS). I wanted added trailer protection when towing so I went with the 16" long flaps. They are the perfect length (for a stock height truck). Just enough clearance that they didn't drag on driveways and curbs when you went over them. There was probably 3-4 inches of clearance. I also went with their Drill-Less model. The rears are solid. The front are pretty secure but there's a finicky bracket that moves and secures to the wheel well liner in addition to the mounting holes in the wheel well.
Putco Window Visors
Line-X
Bak Flip F1
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
4" Solstice Prime
Truck Bed Lights
post #7 of 10 Old 05-01-2012, 07:56 PM
I'll try to post some pics tomorrow. I installed the Ford OEM rear wheel well liners and AirHawk mud flaps. I'm really happy with the combo.
Waxy
Waxy is offline
post #8 of 10 Old 05-02-2012, 05:13 AM
Ranger429's Avatar
I had the OE Ford mudflaps on my old 6.0 and will not use them ever again. I found that they wore into the paint where the mudflap touched.
That Duraflap Alberta posted doesn't touch the paint at all, nice mud flap.
Ranger429 is offline
post #9 of 10 Old 05-02-2012, 07:03 AM
Here's a couple pics of the Ford OEM wheel well liners, it's kinda hard to take a decent pic of them, but hopefully this helps.
They were kinda expensive for what you get, but they install real easily and they definitely close things in and add some protection. I'd do this mod again, I think it was worth it.
Waxy
ID:	37509   Click image for larger version
ID:	37510   Click image for larger version
ID:	37513   Click image for larger version
ID:	37514   Click image for larger version
Waxy is offline
post #10 of 10 Old 05-02-2012, 07:09 AM
Here's a couple pics of the AirHawk mudflaps. I happen to like the chrome/stainless look, but they're available without it as well. Air Hawk Industries : Mud Flaps - Grille Inserts - Box Liners They're in Canada, but they do ship to anywhere in the USA as well.
They're nice and long and they provide really good coverage. They can be mounted with or without drilling. I used a combination of the two methods just for my own peace of mind that they weren't going anywhere. Either way the install is easy and nice and solid.
I'm very happy with these, and I'd definitely buy them again.
Waxy
Name:	Front Mud Flap - small.jpg
ID:	37516   Click image for larger version
Name:	Rear Mud Flap Driver - small.jpg
ID:	37517   Click image for larger version
Name:	Rear Mud Flap Passenger - small.jpg
Waxy is offline
