Suggestions on a leveling kit - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 19 Old 02-23-2012, 05:44 PM Thread Starter
LFD132's Avatar
Quoted: 3 Post(s)
I just want to level my F350 and not mess with the rear blocks. Any ideas?
[SIGPIC][SIGPIC]2013 F250 FX4
LFD132 is offline
post #2 of 19 Old 02-26-2012, 08:32 AM
From what I've read, if you have an F-350 you don't have to swap out the rear blocks. They already are taller than an F-250.
RIDE3311 is offline
post #3 of 19 Old 02-26-2012, 10:09 AM Thread Starter
LFD132's Avatar
Quoted: 3 Post(s)
Yea that's why I don't want to mess with them, but I was trying to figure it what to go with in the front to keep it level. To to it off I find that the drivers side is half an inch lower that the passenger.
Sent from my DROID RAZR using AutoGuide.com App
LFD132 is offline
post #4 of 19 Old 02-26-2012, 10:27 AM
bltp203's Avatar
Well I have the plow package springs so that gave me an inch already, so I just went with the Skyjacker 1" lower coil spacer. I still have a 1/2 inch rake which is perfect because a tow a small landscape trailer and don't want it to squat when I hook up.
There are different sized blocks for every application. They are sooo easy to install. I did everything in 2 hours. Also with 1", I didn't need longer shocks and my alignment stayed within specs.
Skyjacker 1" and 2"
Readylift 1.5"
2012 F-350 CCSB 4X4, plow package, Skyjacker 1" leveling kit, 295/70/18 Nitto's
bltp203 is offline
post #5 of 19 Old 02-26-2012, 10:31 AM
bltp203's Avatar
Forgot to tell you that I have a 1/2 inch difference between drivers and passengers side as well. You can't tell just by looking at it, even after the lift.
Superlift makes 2" coils that will even out that front end from side to side.
bltp203 is offline
post #6 of 19 Old 02-26-2012, 10:33 AM
On my 2011 F350 Lariat CC, I have the Daystar 2 1/2" front leveling kit. Part # KF09119BK. No drama, looks good, all level without the bad ride of a lift kit.
mrock is offline
post #7 of 19 Old 02-26-2012, 11:20 AM Thread Starter
LFD132's Avatar
Quoted: 3 Post(s)
I was looking at the Newton lift they sell on Ebay. Not trying to go cheap on a 60 thousand dollar truck, but I want tires and wheels so I need to keep the cost down and maybe up grade the lift down the road.
LFD132 is offline
post #8 of 19 Old 02-26-2012, 12:13 PM
Skyjacker 1" and 2"
Readylift 1.5"
I have a f350 with the plow package also. If I were to put a readylift 2.5" on the front, it would be too high?
2011 F350 CCSB Lariat SRW
Readylift 2.5" leveling kit
Western SS MVP3 Plow
Hfd137 is offline
post #9 of 19 Old 02-26-2012, 12:20 PM Thread Starter
LFD132's Avatar
Quoted: 3 Post(s)
I have have the heavy duty Service suspension. Whatever that means.
LFD132 is offline
post #10 of 19 Old 02-26-2012, 06:06 PM
Yes, around an inch.
Andrew010 is offline
