Aux Fuel Tank/Tool Box installed - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 8 Old 11-15-2011, 12:28 AM Thread Starter
UpToNoGood's Avatar
Here are some pics of my install.
First I have to say the two side mounting tabs would have hit the sides of the truck where it rolls up and wouldn't have laid flat and would make mounting it a pita.
So I made the 1x1 inch frame to mount it on and now the side tabs are not an issue. And instead of running the hose through the ruff edges of the bed I installed the bulkhead fitting.
Once the hose goes under the bed it connects to a fuel filter then a fuel pump and finally a solenoid valve. I have them wired to up lifter switch #3 in the cab. I also added a blinking LED down low so I can see when I am transferring fuel and don’t forget to shut it off.
Now if I need to remove the tank I can unbolt it from in the bed and leave the frame attached never having to crawl under the truck again.
ID:	30595   Click image for larger version
ID:	30596   Click image for larger version
2012 F250 CC Lariat 4x4 Tricoat White
UpToNoGood is offline
post #2 of 8 Old 11-15-2011, 06:34 AM
mor4wd's Avatar
Very clean install. I like it. How much fuel does it hold and what brand is it. I've looked at the TransferFlows and they're way too much money.
2011 F350 Lariat SRW Crew Cab Long Bed 4x4 6.7 H&S Mini Maxx DPF Delete EGR Delete running 265/70/19.5's
Originally Posted by magzne1 View Post
Chevy comercials are like OBAMA, ALL B.S. over promise and under deliver
Originally Posted by trevor73402 View Post
This stuff isn't as simple as tuning your TiVo to record your Jerry Springer re-runs while your out cruising Wal-mart parking lot for transexual hookers.
mor4wd is offline
post #3 of 8 Old 11-15-2011, 06:36 AM
It's made by RDS, Northern Tool sells them. That one looks to be a 40-50 gallon model
Sent from my GT-I9100 using AutoGuide App
2012 F350 Lariat SRW CCSB 4x4 - Vermillion Red
Icon 7" Lift, BMF Novakane, 37x13.5x22 Toyo MT, MBRP Filter Back, 2WD Chin Spoiler, RDS 150 Gallon Tank
turboryan is offline
post #4 of 8 Old 11-15-2011, 12:35 PM Thread Starter
UpToNoGood's Avatar
Yes it is an RDS 40 gal tank.
post #5 of 8 Old 12-04-2011, 09:24 AM
Will the RDS tank gravity drain into the main?
littlefield is offline
post #6 of 8 Old 12-04-2011, 09:28 AM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
Thats awesome.
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, TW tunes, 4" DP, Napa Intake, coolant filter, 140cc Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
post #7 of 8 Old 12-04-2011, 11:00 AM Thread Starter
UpToNoGood's Avatar
Yes it will gravity feed if you have the RDS kit that NorthernTool sells. I used the kit but cut the gravity feed part off due to having the pump and 12 volt shut off valve.
post #8 of 8 Old 12-04-2011, 12:12 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Looks good, Good job!
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
