Need driver side passenger door handle - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 11 Old 11-07-2011, 05:55 PM Thread Starter
TXGold's Avatar
I want to replace the drivers door handle on my black 2011 with a driver side passengers door handle because it doesn't have a key hole.
Does anyone have experience doing this?
Anyone have a part number?
2014 Ram 2500 MC Limited Black/Black, 295/65R20 Toyo AT2Ext's, Thuren 2.5 Springs, Fox/Thuren 2.0 ITP Shocks
TXGold is offline
post #2 of 11 Old 11-17-2011, 07:44 AM
Dont Mess With Texas!
ThirdCoastStroker's Avatar
Quoted: 14 Post(s)
i dont have a part number but go to a junk yard or order a replacement REAR DRIVER SIDE HANDLE, same thing, that is what people are using these days.
Casey
New Truck
15' F-350 King Ranch 4x4 CCLB
Platinum White / Caribou Metallic
Stock for now!
Old Truck
08' F-350 King Ranch 4x4 CCSB
H&S Mini Maxx 300 HD
5" Straight Pipe to 7" rolled tip
AFE S2 PDS
ARP Head Studs
FloPro EGR Delete with Intake Elbow
FloPro CAC pipe
Rebuilt beefed up OEM Up pipes
Deisel Site Coolant Filter
Firestone RideRite Airbags
Leveled
35X12.50R20 ProComp Xtreme A/T
Ranch Hand Front and Rear Replacement Bumpers
ThirdCoastStroker is offline
post #3 of 11 Old 11-17-2011, 08:42 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
What happens if your rig is locked and you lose your key fob away from home or the battery in the key fob dies???
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #4 of 11 Old 11-17-2011, 08:59 AM
Quoted: 14 Post(s)
idk, i thought the same thing, but there are alot of people out there who are doing that.
Casey
New Truck
Stock for now!
Old Truck
AFE S2 PDS
ARP Head Studs
FloPro CAC pipe
Leveled
post #5 of 11 Old 11-17-2011, 09:01 AM
Quoted: 4 Post(s)
Subscribed...
Larry
14,000 LB GVWR,
Spray In Bed-Liner,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
post #6 of 11 Old 11-18-2011, 12:31 PM
MDarrough's Avatar
Quoted: 2 Post(s)
I would think a locksmith could get you in with a slim-jim.
Mark
2011 F-350 4X4 Dually Lariat pulling a 2010 Sierra 355QBQ 5er --
MDarrough is offline
post #7 of 11 Old 11-19-2011, 10:26 AM
matty21's Avatar
Mark
Just grab an extra drivers side window from the wreckers and a brick.
2015 F350 King Ranch
monochrome tuxedo black, every possible option.
Ordered April 30, 2014
Yet to be delivered
2011 F350 KingRanch 6.7L
AFE stage 2 intake
H&S tuner 4" straight pipe
dual 6" MBRP black stacks. DPF, DEF, EGR Delete
ZEX NOS kit with .088 jet
08 Harley Davidson F350
6" lift with 36x15.50x20's
spartan tuned and deleted.
matty21 is offline
post #8 of 11 Old 11-19-2011, 02:21 PM
How about the numbered keypad on the drivers door to get it? Figured that would of been a no brained. Haha
Current Rig: 2011 F-350 CCSB Lariat chrome FX4 Tuxedo Black.
Mods: aFe stage II, 8000k HID. 6" 4link Skyjacker Lift, 37" Toyos Wrapped around 20x9 XD MisFit Rims, H&S Minimaxx, 5" FloPro straight pipe
Traded: 2006 F-350 CCSB Amarillo Edition
Mods: 6" BDS 4-Link Lift Kit, 4" MBRP Cool Duals Exhaust, AFE Intake, Edge CTS Evo, 37x13.5x20 Toyo MT wrapped around XD Spy 20x9 Rims
UA Local 488 Steamfitter/Pipefitter
AlbertaStroker is offline
post #9 of 11 Old 11-20-2011, 07:11 PM
MDarrough's Avatar
Quoted: 2 Post(s)
What if the truck battery is dead?
post #10 of 11 Old 11-20-2011, 07:19 PM
str8wkd's Avatar
if I'm not mistaking if the batt die you can hook power to the trailer brake plug and it will back feed and let you unlock it
04 F350
Extreme Street tooon (By Eric)
Harley Lights
S&B cold air kit (lid delete = more air)
Sinister Coolant bypass
MBRP 4in straight piped
Alpine in dash tv,
Limo windows,
55watt hid headlights
35watt hid fogs
Smoked roof lights
Mephis audio highs
Sub box w/ Mephis Pr's
Edge Insight CS
Studded, Deleted, powermaxed
86 Iroc (slightly modded
) 383 stroker pro 1 alum heads 69 302 race cam 8 point roll bar frame connectors 350 turbo trans welds
str8wkd is offline
