Headache Rack - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 17 Old 10-16-2011, 05:20 PM Thread Starter
UpToNoGood's Avatar
Headache Rack
Here is an image of the headache rack I want to build. Everything is normal for a headache rack but the receiver tube at the top. I added that for a winch 2000-2500 mounted to a hitch that can be pinned when needed and removed when not. I elk hunt alone a lot and using the winch an a ATV ramp makes getting the elk in the back easy for 1 person.
I made it using Google sketchup
2012 F250 CC Lariat 4x4 Tricoat White
UpToNoGood is offline
post #2 of 17 Old 10-16-2011, 05:31 PM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
Thats a good looking rack.
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, TW tunes, 4" DP, Napa Intake, coolant filter, 140cc Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
post #3 of 17 Old 10-16-2011, 06:57 PM Thread Starter
UpToNoGood's Avatar
What do you guys use to run wire through the insides to prevent them from getting cut on sharp edges?
post #4 of 17 Old 03-05-2012, 01:01 AM Thread Starter
UpToNoGood's Avatar
Finally finished the rack and got it installed. Here is a picture.
I need to add the lights and winch for the receiver tube.
post #5 of 17 Old 03-05-2012, 02:14 AM
cweiss87's Avatar
That looks good. Good job
04
F-250 FX4.
Sct X2 with tunes from Gearhead
Zoodad mod
High idle mod
Straight pipe exhaust
BDS leveling kit
Stage 1 intake
cweiss87 is offline
post #6 of 17 Old 03-05-2012, 06:17 AM
MDarrough's Avatar
Very nice!!!
And great idea with the receiver for a winch!!
Mark
2011 F-350 4X4 Dually Lariat pulling a 2010 Sierra 355QBQ 5er --
MDarrough is offline
post #7 of 17 Old 03-05-2012, 08:28 PM
Alberta Advantage's Avatar
Quoted: 19 Post(s)
That is a very good looking headache rack. Split loom will probably provide the best protection but is also the most difficult to work with in an enclosed space without making large entry and exit holes. Thicker heat shrink will be the easiest as you can just pull the wire through but will only offer a little additional protection. You'll still have to be pretty careful pulling the wire.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #8 of 17 Old 03-20-2012, 07:52 PM
Looks awesome
bursty is offline
post #9 of 17 Old 03-21-2012, 02:42 PM
Scubamax's Avatar
Off topic, but same topic... I had an old man make me look like a fool once. I killed a 225 lb hog and could not lift it into the back of my truck. Fought with it for several minutes and almost gave up and cut the sucker up in the field. I went back to the camp and asked the last guy left to come give me a hand. He just laughed at me and taught me a good one. Get a long rope, tie one end to the hog round it's neck, other end to a tree, hook rope over gooseneck ball and drive forward. Hog loaded itself. I bought the ol' man a 12 pack of beer and he shared it with me. The winch is a great idea by the way. lol
94% of all Dodge Cummins trucks from1992 through 2012 are still on the road today..... The other 6% made it home.....
2012 F250 Lariat FX4
H&S Mini Maxx
Deleted MBRP 4" W/Muffler
EGT blocker plate
If it still runs when you delete it, you don't need it!
Scubamax is offline
post #10 of 17 Old 03-21-2012, 03:00 PM
Quoted: 338 Post(s)
Feedback Score: 5 reviews
Stupid question... can you explain more please ?
I cant picture it in my head.....
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
