Clearance Lights - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 22 Old 10-04-2011, 05:56 PM Thread Starter
Clearance Lights
is it just me or do a lot of the new fords not have clearance lights? i mean im in the process of buying one of the last 2011 lariats on the lot and even though the trucks have been picked over they have 20 plus super dutys on the lot and mayve 3-4 of em have clearance lights and they are work trucks?
anyways talked to the dealer about getting them put on the truck im trying to buy on their dollar and they said no way because its a 400$ project..... seems kinda absurd for something that is a 55$ option.... anyone have any experience installing these? is it a pain? do you just drill holes in the roof to mount? or do you have to cut the shape of the light out?
i refuse to drive a one ton truck towing a goose with 18,000 with a truck with no damn clearance lights also i forgot truck has a moon roof probably makes it tougher right? i know theres room for em though i looked!
2005 ex lb drw lariat bone stock
DuallyDick is offline
post #2 of 22 Old 10-05-2011, 06:12 AM
1. It is available from the factory
2. I'd order the truck as such from the factory so you don't have to go pokin' holes in your roof
3. Find a different stealer -If they refuse to do any factory-based upgrade they obviously:
a. Don't know how
b. Don't have time
c. Want you to save money
From what i've seen on the Ford website (pictures on the Builder) is on the 250 Lariat it is optional, the 350 Lariat is standard (correct me if im wrong)
Jimmy7060 is offline
post #3 of 22 Old 10-05-2011, 06:55 AM
Retired
Sgt93's Avatar
I have heard of $400-600 for install. To do it yourself, you must measure the lights for spacing etc (someone on FTE made a template), cut the holes, remove the roof liner, install harness etc. I thought about it but do not want them bad enough that I am going to drill holes in my roof.
2015 Ford F350 King Ranch SRW SB 4x4 loaded, RetraxPro, Andersen Rapid Hitch.
Ordered: 04/29/14
Built: 05/20/14
Delivered: (projected 06/04/14)
2013 Jeep Rubicon Unlimited
SOLD 2011 Ford F250 Lariat 6.7 PS CC 4x4 SB 3.55 with a bunch of crap.
Sgt93 is offline
post #4 of 22 Old 10-05-2011, 11:01 AM Thread Starter
the truck is a 350 lariat no clearance lights and they have 3 other 350 lariats without them... and the dealer didnt say they wouldnt do them they just said they wouldnt throw them in the deal for free
post #5 of 22 Old 10-05-2011, 11:03 AM Thread Starter
and i cant ordera truck because i cant order 2011 and order it with the 12k dollars off in rebates im gettin if i order i pay 60k
post #6 of 22 Old 10-05-2011, 11:09 AM
Same problem here, just bought 2011 and couldn't find one either with lights. I"m like Sgt though I will not put holes in new truck unless you do it at dealer and ford includes upgrade in your warranty. Did you ask dealer about warranty from leaks if they install?
cajun11screw is offline
post #7 of 22 Old 10-05-2011, 12:09 PM
I asked my dealer about adding the lights to my 08 SD and they said that it was around $450. They have to drop and replace the headliner, etc, etc. Plus, I worry that they wouldn't seal it properly or that it would rust. I didnt have them do it. Good luck.
BlueF350 is offline
post #8 of 22 Old 10-05-2011, 12:38 PM
Joel's Avatar
Quoted: 10 Post(s)
Its about the easiest upgrade I've done to my truck.
We did my 2002 and my buddies 2008 which has a sunroof both in the same day. Took a total of about an hour and a half including full wiring.
That was over a year ago, and we live in Vancouver BC where it rains about every day and we have had no problems with leaks.
Just buy the recon kit as it comes with a guide for measuring where the holes go.
Also, dont waste your time dropping the headliner. Remove both A pillars and let it sag just a little, thats all the room you'll need.
The 2008 with sunroof was actually easier because you could stand up through there to drill the holes.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #9 of 22 Old 10-05-2011, 05:29 PM
BigPSD is offline
post #10 of 22 Old 10-05-2011, 05:30 PM
I Thought I read the Wires are already there for the Lights?
Biggest issue would be getting them straight,and then doing some kind of rusts prevention on the Drilled holes!
I also thought i read about Recon sending a template with their lights ,but Im not sure...
You Half to have a template If you want them Dead on or super close...
You should be able to fold this template in half and all the holes match/Line up ...
Lead Foot is offline
