6.7 OIL FILTER - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 11 Old 09-21-2011, 12:49 PM Thread Starter
GLIofMI's Avatar
6.7 OIL FILTER
I found cheap WIX oil filters at,
discountfleetsupply.com
$15.02 each, bought 10.
Better than $25 at the parts store, some want $50??????????
From what I know you shouldn't be running any other filters anyway.
Plus I am running AMSOIL.
Don't buy cheap parts, just pay cheap prices for the best parts.
Name:	TRUCK TOW PIX.jpg
GLIofMI is offline
post #2 of 11 Old 09-21-2011, 03:43 PM
Ryan2011dieselpower's Avatar
Shop at Dieselfiltersonline.com located in New Jersey
$10 bucks for the Motercraft FL-2051, i just bought 2....
Ryan2011dieselpower is offline
post #3 of 11 Old 09-21-2011, 09:29 PM
mor4wd's Avatar
FYI if you go in for warranty service with a non Motorcraft filter they may deny work. Lot of people dealt with that with the 6.4.
Sent from my Autoguide iPad app
2011 F350 Lariat SRW Crew Cab Long Bed 4x4 6.7 H&S Mini Maxx DPF Delete EGR Delete running 265/70/19.5's
Originally Posted by magzne1 View Post
Chevy comercials are like OBAMA, ALL B.S. over promise and under deliver
Originally Posted by trevor73402 View Post
This stuff isn't as simple as tuning your TiVo to record your Jerry Springer re-runs while your out cruising Wal-mart parking lot for transexual hookers.
mor4wd is offline
post #4 of 11 Old 09-22-2011, 02:40 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
This has happened more than once so measure twice cut once!
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #5 of 11 Old 09-22-2011, 03:27 AM Thread Starter
GLIofMI's Avatar
Thanks for the heads up, I'll get me a motorcraft filter in case I need to take it in.
But there is no way I will run anything but a Wix or Amsoil filter.
Nothing but synthetics here.
GLIofMI is offline
post #6 of 11 Old 10-01-2011, 02:48 PM
harrysmith500's Avatar
You and me both will be putting Motor craft when we take them in haha.
Does the Napa gold filter series come from Wix?
Did you switch all of your trans. cases, trans, and diff's to Amsoil in addition to the motor oil?
Duratrac's FTW
2012 F-250
From the Beehive State
harrysmith500 is offline
post #7 of 11 Old 10-02-2011, 10:58 AM Thread Starter
GLIofMI's Avatar
I am not sure about the NAPA thing.
Somewhere in the POWERSTROKE forums there is a comparison of a bunch of filters.
If I find it again I'll link it. Good stuff.
It maybe a Amsoil web site thing?
I have not switched the rest yet because what they put in at the factory is good stuff.
If I get slow and have extra money then yes, I will switch the rest sooner than later, rear end first, tranny second, then front end.
And you?
GLIofMI is offline
post #8 of 11 Old 10-05-2011, 08:23 AM
The NAPA filters are made by WIX. Hopefully Amsoil will come out with a filter soon.
strkngator is offline
post #9 of 11 Old 12-20-2011, 04:36 PM
hcfd63's Avatar
I got the OEM filter from Advance Auto - they don't stock it, but could get it in the store in 1 day, was about a wash on price compared to the best price online once you factor in shipping. FoMoCo filters are good enough for me.
2011 F-350 CCLB SRW King Ranch 4x4
hcfd63 is offline
post #10 of 11 Old 10-28-2012, 02:44 PM
johnh7's Avatar
do we have other options when it comes filters and oil?? i know when i had the ram with cummins i had lots of options for filters but with the 6.7 powerstroke im not sure.
-- John Huber -- SGT RET --
l'12 F-250 King Ranch l Black Tuxedo l
johnh7 is offline
