4x4 dually lowering? - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 5 Old 09-18-2011, 06:08 AM Thread Starter
matty21's Avatar
im looking to lower the front end by 1-2" then make the rear level with the front and putting bags back there for hauling .
what is the best way to do this? ive seen tonnes of lifting kits available but no lowering kits after lots of searching the internets.
2015 F350 King Ranch
monochrome tuxedo black, every possible option.
Ordered April 30, 2014
Yet to be delivered
2011 F350 KingRanch 6.7L
AFE stage 2 intake
H&S tuner 4" straight pipe
dual 6" MBRP black stacks. DPF, DEF, EGR Delete
ZEX NOS kit with .088 jet
08 Harley Davidson F350
6" lift with 36x15.50x20's
spartan tuned and deleted.
matty21 is offline
post #2 of 5 Old 10-23-2011, 05:43 AM
Your best bet for the front would be to either cut 1 full coil off your front springs, or go with a gasser spring. I've heard the gasser springs will give 1-1.5" drop up front, out back things should be much easier, just experiment with the factory blocks back there. Being that your is already a F350, to level with your future dropped front, you'd prob need pull the 4" or 5" block, that should get you close to level.
highdrum is offline
post #3 of 5 Old 10-23-2011, 10:59 AM
A 250 rear block would help. And the front. Maybe check out Topgun Customz. Get a set of springs made maybe. I wouldn't ever cut a coil down to size tho
Current Rig: 2011 F-350 CCSB Lariat chrome FX4 Tuxedo Black.
Mods: aFe stage II, 8000k HID. 6" 4link Skyjacker Lift, 37" Toyos Wrapped around 20x9 XD MisFit Rims, H&S Minimaxx, 5" FloPro straight pipe
Traded: 2006 F-350 CCSB Amarillo Edition
Mods: 6" BDS 4-Link Lift Kit, 4" MBRP Cool Duals Exhaust, AFE Intake, Edge CTS Evo, 37x13.5x20 Toyo MT wrapped around XD Spy 20x9 Rims
UA Local 488 Steamfitter/Pipefitter
AlbertaStroker is offline
post #4 of 5 Old 10-23-2011, 01:09 PM
Pahrump's Avatar
Theres no kits....pull the rear block all the way out.....cut about 1 to 1.5 COILS off the front and roll out...it will be as low as you can get...will look about like my F250 did...
I know its not a 6.7 but its the same suspension
2008 F250 FX4 CC SB Black on Black STOCK and SLOW...Rolled over and TOTALED...
2008 White with Black interior FX4 CCSB
Black C6 Vette
As far as actual HP numbers I have no idea. It don't snap your neck but.....It feels good.
Pahrump is offline
post #5 of 5 Old 12-01-2011, 03:31 PM
was wondering if you ever lowered your dually? was thinking about doing the same thing and wanted to know how yours turned out
jrbonniwell is offline
