Pressure Washer Selection - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 3 Old 05-20-2011, 03:50 AM Thread Starter
Hi, has anyone out there bought one of the troy units from Lowes in the last year or so, and are you satisfied with it? Would you have another suggestion in this range that is reliable? I would like to limit my cost to $350.
Ernesto152 is offline
post #2 of 3 Old 05-21-2011, 03:57 AM
Quoted: 5 Post(s)
I have a 3000# PSI Troybuilt unit I got a month or two ago...
Its ok, for light use, as everyone else said, if you need alot of pressure washing done, get a rental unit, or you will pay 1k plus.
One thing about the <$500 units, the PSI is fixed, you can only change the output by switching nozzles...
UrbanKnight is offline
post #3 of 3 Old 05-23-2011, 09:14 AM
mor4wd's Avatar
A good thing to look for when buying a light duty pressure washer is the engine. The pumps are all typically good units, you want to get a good solid made engine like a Honda. I know Craftsman and Karcher use Honda. 3000 PSI is ok but I'd look for something in the 3500 to 4500 range if you want to get anything other than mud off.
2011 F350 Lariat SRW Crew Cab Long Bed 4x4 6.7 H&S Mini Maxx DPF Delete EGR Delete running 265/70/19.5's
Originally Posted by magzne1 View Post
Chevy comercials are like OBAMA, ALL B.S. over promise and under deliver
Originally Posted by trevor73402 View Post
This stuff isn't as simple as tuning your TiVo to record your Jerry Springer re-runs while your out cruising Wal-mart parking lot for transexual hookers.
mor4wd is offline
