ICON 2.5 lift - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 24 Old 02-28-2011, 08:24 AM Thread Starter
ICON 2.5 lift
So I am still debating getting the ICON 2.5 or just heading to 4Wheel parts and getting whatever 2inch they sell..
The end goal is to maintain ride quality and clear my tires without rubbing and not be abnormally tall.
Honestly the stock wheels are perfect IMO I just want a wider tire. I am debating between these two.
BFG All-Terrains
LT325/60R20/E = 35.4 $$$$
LT285/65R20/E = 34.7 $$
Anyone have experience with these on a f-250 running the lifts above or be able to point me to something that will help out.. PICS would be ideal, seems hard to find with people running these on stock wheels which is what I want.
mg1098 is offline
post #2 of 24 Old 02-28-2011, 09:22 AM
Slacker
Evil Eye's Avatar
Quoted: 199 Post(s)
Feedback Score: 4 reviews
I'm running the Icon 2.5" progressive spring leveling kit on my truck and LOVE it. Our front ends are set up almost identical, so yours would be setup similarly. Depending on width of tire (mine were about 13" wide and they would rub just slightly at full lock), the tires you are looking at shouldn't rub at all with the Icon setup.
BTW, welcome to the ORG!
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #3 of 24 Old 02-28-2011, 12:00 PM Thread Starter
Thanks... The tires I think I want the most are the 325's but I dont know anyone that squeezed them onto stock wheels with a 2.5 to let me know if they fit or not.
mg1098 is offline
post #4 of 24 Old 02-28-2011, 07:53 PM
cjm09's Avatar
I am running the 325/60/20 BFG AT on my 350. they are just rubbing a little bit. I am going to install a set of step back mud flaps, and I think this should fix the problem. I am running these on a Rev teck 2.5" leveling kit.
Also, as measured on the truck, the 325's measure out at exactly 12" wide, and exactly 35" from level floor to top of tire. As stated, this is while on the truck. I also have these on factory rims.
Hope it helps
cjm09 is offline
post #5 of 24 Old 03-01-2011, 06:49 AM Thread Starter
Hope it helps
That would be awesome if you had a set of pics of this setup...
Not sure how a set of mud flaps help ?? I assume they Rub at full lock ?
mg1098 is offline
post #6 of 24 Old 03-01-2011, 02:40 PM
cjm09's Avatar
I will see if I can snap a couple for you. yes, at full lock the mud flaps will rub a bit.
cjm09 is offline
post #7 of 24 Old 03-01-2011, 03:13 PM
cjm09's Avatar
Here are a couple of pictures.
ID:	23248   Click image for larger version
cjm09 is offline
post #8 of 24 Old 03-01-2011, 04:07 PM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
You can run 35" without any problem..but if you want a lift 2.5" the Icon is best..for a few months that is..something new is coming..
CT Performance, Inc. is offline
post #9 of 24 Old 03-01-2011, 06:09 PM Thread Starter
Great, something new ? Unless it can let me run those BFG's without any rub or modification then Its likely not of interest to me.. I dont like the idea of being able to fit the tire,
but having it rub when i turn..
Truck looks great btw, where does the tire rub ?
mg1098 is offline
post #10 of 24 Old 03-01-2011, 07:10 PM
cjm09's Avatar
Thanks. It just catches the bottom of the mud flap. I have a set of step backs, now just have to get them on. It only catches at full turn right now, so this will fix the problem.
cjm09 is offline
