level kit rub - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 11 Old 02-22-2011, 06:37 PM Thread Starter
cjm09's Avatar
level kit rub
Hey guys, just put on a Rancho 2.5" leveling kit along with 325,60,r20 BFG AT. I am surprised to find that i rub at full turn. I also find that the truck wanders a bit on the highway. anyone else experience this, or do I have a bigger issue. My last Ford, 06 F350, had no issues with a Pro Comp set up.
Any Ideas are appreciated.
Thanks
cjm09 is offline
post #2 of 11 Old 02-22-2011, 06:50 PM
majek5's Avatar
Did you get it aligned after the lift? What pressures are you running?
2006 F350 CCLB KR FX4
stock...
majek5 is offline
post #3 of 11 Old 02-22-2011, 07:15 PM
FastStrat's Avatar
Rub on the radius arms can be caused by wheels with to much positive offset, 'specially on a tire that is almost 13 inches wide.
Just because you bendin' strings...doesn't mean your playin' the blues.
FastStrat is offline
post #4 of 11 Old 02-22-2011, 07:39 PM Thread Starter
cjm09's Avatar
hey guys, thanks for the reply's. I did make a mistake, it is a Revteck 2.5". I do believe I am rubbing on the mud flaps, which i thought was a little odd. I am also only rubbing when fully turned to the left. The right seems to be OK. I was told they did an alignment, but i may have to double check.
Thanks again guys
cjm09 is offline
post #5 of 11 Old 02-23-2011, 04:58 PM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Did it come with a adj track bar or a drop track bar bracket..if not the axle shifted 1" aprox..we have the bars if you need it.
cary
CT Performance, Inc. is offline
post #6 of 11 Old 02-23-2011, 07:41 PM Thread Starter
cjm09's Avatar
Thanks Cary I will have to check. I had it installed by a shop that specializes in these. I will have to find out.
cjm09 is offline
post #7 of 11 Old 02-25-2011, 06:56 AM
teameyecatcher's Avatar
I just put a 1.5 kit on mine and I have no rub at full turn with 35x12.50x20's on factory wheels. I'm surprised you do
2011 6.7l F-250 Lariat FX4. Tuxedo Black with tan bottom/Black interior
-2" Readylift
-Avery clear bra/painted grille surround, KR bumpers
-Recon LED cab light kit, dually under tailgate light.
-Black bedlined toolbox. Black bedliner, dual cable locks, and factory bed extender
-Yellow tops, lockpick.
-Legal window tint
teameyecatcher is offline
post #8 of 11 Old 02-25-2011, 11:53 AM
Quoted: 3 Post(s)
You have a '11 you can run 35" stock, he has a '06..different requirements.
post #9 of 11 Old 02-25-2011, 12:23 PM Thread Starter
cjm09's Avatar
No this is an 11, F350. The tires are sized at 325 (12.8") 60,20. This measures out to actually be 12" wide exactly, and 35" tall mounted on the truck. I am surprised that it is rubbing as well. Is it possible my axle is now sitting to far back in the wheel well?
cjm09 is offline
post #10 of 11 Old 02-28-2011, 07:58 PM Thread Starter
cjm09's Avatar
Found It!!! My installer "missed a step" they needed to install some supplied bushings on the ball joints to correct the caster. After i spoke to RevTeck, we realized this step got missed. Back to the shop. Guys were good, they took care of it, adn it is night and day difference.
cjm09 is offline
