wheel offset/backset help needed. - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 2 Old 01-31-2011, 07:17 PM Thread Starter
Im buying some Fuel Offroad -hostage rims
20x10. They come in either a 4.5" backspace / -24mm offset or 5" backspace / -12mm offset.
I have a 4.5" lift and am going to run 35" tires.
I want the tires to stick out and have a nice wide stance.
Which backspace/ offset should i get?
They also make a 20x9 with 5"/-1mm and 5.5"/-14
Thanks for any help guys
goodoleboy is offline
post #2 of 2 Old 02-03-2011, 12:58 PM
KYmxracer52's Avatar
Go with the 4.5" backspace. The less backspacing, the more they stick out. You may or may not rub a tad with the 4.5". I like the looks of those better than 5" BS. Do the 20x10.
2005 F-250 CC SB-SCT,Edge Insight,5" MBRP, 5" ProComp lift, dual-stabilizers, 35x12.50 Federal Couragia MT, 20x10 Fuel Hostages, B&W ball, Truxedo roll cover
KYmxracer52 is offline
