Torque App (specific to 6.7) - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion 6.7 Electronics Discussion
post #1 of 8 Old 07-03-2014, 07:01 PM Thread Starter
Guest
I know there is a thread over in the general forum about the android app "Torque" and various PIDs and configurations. Anybody have a setup that is working great for a 6.7L? I just received an OBDLink MX bluetooth transmitter and I'm pretty sure I've downloaded the Ford PIDs, but I'm still sorely disappointed by the variables that are available. Let's see some 6.7 setups and whether you're happy with it.
Thanks!
gone is offline
post #2 of 8 Old 09-05-2014, 03:38 PM
I found 6.7 specific pid's as an installable .apk on one of the other forums and it saved a lot of time.
Not all work but I use all 3 get, dpf percentage and regent status 0/1 or on/off) in my daily commute.
If anyone has any good custom pid's I would love to see them.
2012 F-350 regular cab 4x4 xlt.
Tow and plow options.
Tonneau cover.
Remote start/turbo timer.
Kenda Klever 265 70 17 M/T's
bgroves is offline
post #3 of 8 Old 12-31-2014, 10:16 AM
SuchTrk's Avatar
Quoted: 2 Post(s)
Garage
I am running an Android stereo with several custom PIDs. tho im not sure how many are included in the app now. I'm at work at the moment but i have another forum that i bookmarked at home that has alot of custom PIDs that can be input into it. Ill link it when i get home
2011 F350 4x4 XLT Super Cab,
Nexus 7 dash install.
H&S Mini Maxx- Delete Tunes
DP back Flo Pro Dual Exhaust
EGR Delete with pass-through plate
No Limit Stage 2 5" intake
more to come
SuchTrk is offline
post #4 of 8 Old 12-31-2014, 11:21 AM
SuchTrk's Avatar
Quoted: 2 Post(s)
Garage
here is the link to the other forum. i'm using about half of them or so. Torque Pro Ford 6.7L Extended PIDs - Ford Truck Enthusiasts Forums
more to come
SuchTrk is offline
post #5 of 8 Old 01-01-2015, 06:35 AM
Quoted: 45 Post(s)
I could never get the Soot % to read correctly. Mine showed over 100% close to 150%
Is there an updated equation for this?
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Camper Package, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
post #6 of 8 Old 01-01-2015, 09:12 AM
SuchTrk's Avatar
Quoted: 2 Post(s)
Garage
i'm using the equation off of that site for soot level and mine is showing fine. regen starts at 98% most of the time
more to come
SuchTrk is offline
post #7 of 8 Old 01-01-2015, 11:34 AM
OutlawII's Avatar
Quoted: 3 Post(s)
I was using the pid's off that link also and mine started reading in the negative for soot level's so i uninstalled the app will try it again when i go back to work.
OutlawII is offline
post #8 of 8 Old 02-25-2015, 03:46 PM
SuchTrk's Avatar
Quoted: 2 Post(s)
Garage
I read that can be caused by the system recalibrating. something to do with soot that won't burn away so it resets the new level to 0 and that can cause it to read negative for a bit till it finishes the cycle
also sorry for the late reply went on travel for work and was away from my pc.
more to come
SuchTrk is offline
