Pac aoem-frd24 for 2005+ fords problem - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion 6.7 Electronics Discussion
post #1 of 4 Old 07-02-2014, 04:15 AM Thread Starter
Anyone else had one of these boxes fail to provide a remote amp turn on? The RCAs are active when jumping the power to the remote turn on at the amp. I multi-metered both sides of the Pac box and neither side blue/white is hot. My next step is to pull the radio again and see if something is wrong at the intercepting harness but figured I'd ask.
2012 F250 CCSB 6.7 (3.73 gears) H&S Minimaxx (My own tuning), H&S 64mm turbo kit, H&S Dual Fueler, H&S Low Pressure Fuel System, H&S CCV delete, No Limit s2 Intake, PMF 3-link, PMF traction bars, Fox 2.0s, Icon 2.5" coils, Platinum 20s w/ 295/65 toyo at2s, Airlift bags and wireless controller, TFI 50gal, rollX, AMPboards,
jcain is offline
post #2 of 4 Old 07-02-2014, 07:13 AM
IronCobra's Avatar
Quoted: 8 Post(s)
I have the Frd1 and havent had any problems.
2016 F450 Platinum FX4 CC LWB
2016 Chaparral 360IBL Fifth Wheel: 15,500lbs
GONE - 2011 F250 FX4 6.7L Lariat Ultimate
IronCobra is offline
post #3 of 4 Old 07-02-2014, 07:20 AM
Heavy_GD's Avatar
Quoted: 963 Post(s)
Feedback Score: 3 reviews
If the blue/white isnt hot you have to check the other side of the box to see if you have power coming in.
If no power coming in, then check the factory harness at the plug.
GD - 06 CCSB FX4 Lariat
https://www.gofundme.com/2464axqr
Originally Posted by 6.0Stroker View Post
It's Toren. .. don't question it ..
Heavy_GD is online now
post #4 of 4 Old 07-02-2014, 07:22 AM
IronCobra's Avatar
Quoted: 8 Post(s)
I agree. I believe that is a passthrough wire and should not be effected by the pac unit since it would serve no function to modify its intended purpose. use a multimeter and check te lead coming from you headunit.
